11th Gen mainboard (no battery) – external monitor black via HP docks unless separate USB-C power is connected
Hi everyone,
I have two Framework 13 11th Gen Intel mainboards, each installed in a Cooler Master Mainboard Case. One runs Windows and the other runs Linux. Both have encountered the same issue when connected to either of the following HP docks:
  • HP USB-C G5 Essential Dock
  • HP Thunderbolt Dock G2
Symptoms
  • When either mainboard is connected to a dock, the USB mouse, keyboard and Ethernet all work normally.
  • The external monitor connected through the dock stays black.
  • The monitor only works when I additionally plug a separate USB-C power adapter directly into the mainboard.
Question
Is this expected behaviour for an 11th Gen mainboard without a battery? Could the issue be related to the mainboard failing to negotiate power delivery from the dock, causing DisplayPort Alt Mode to fail?
More importantly, what is the underlying cause of this issue where a separate power adapter is required to get the dock’s external display working? Are there any known solutions or workarounds?
How can we get the external monitors working through the HP docks on 11th Gen Intel mainboards without needing a separate power adapter connected directly to the mainboard?
System details
  • Product: Framework Laptop 13 mainboard, 11th Gen Intel Core (in Cooler Master Mainboard Case, no battery)
  • OS: Windows (board 1) and Linux (board 2)
Thanks in advance for your help!
