13 Pro Screen on a Framework Chromebook
I have a Framework Chromebook. The upgrade page says that the new 13 Pro screen is a direct drop-in on the original Laptop 13. It’d be a great addition to my Chromebook, but I wanted to make sure that it would work for me since the Chromebook is a thing unto itself.
It’s NOT compatible! The product page says so very explicitly:
Thank you! I kind of figured it would be that way. I was going on the quote on the upgrade page “Yes. The Touchscreen Display is a drop-in replacement for any Framework Laptop 13.”
