So i bit the bullet and went from a binary distro to add the framework 16 to my gentoo fleet.
This is the most issues i’ve had with a laptop since my first linux machine the inspiron 5200 p4-mobile. It’s on the latest available bios btw.
Discrete and Optimus: I have full keyboard functionality, brightness controls work. Prime works out of the box with ‘DRI_PRIME=’. Bluetooth works. I would love to leave it here but…
Display managers will not load if more advanced than lightdm. No desktop will load on the first try, will always result in black screen and a cursor. Applications may start or may not start. Always have to switch to vt, restart it and it may start.
In hybrid mode: absolutely no keyboard brightness controls. yes i’ve used the kernel switches. this so far works the best. allowing manual injection to the sysfs value.
nvidia.NVreg_EnableBacklightHandler=0 amdgpu.backlight=0 acpi_backlight=native
Oh and for some reason i cannot find. Hybrid mode kills bluetooth. the driver loads. the firmware loads. it shows up in lsusb. bluz does not see it. trying to enable it crashes anything that sees it.
