240w Charger not working well
This isn’t really the laptop itself but I found today that no matter what I do my 240w charger will only provide 58w to a battery bank with a display that shows wattage and my framework 16 in which battery decreases even when plugged in. This has happened before when the USB-C cable was not fully plugged into the brick. I think this is still the case now but it is impossible right now for me to push the cable fully into the brick for some reason. For an expensive charger like this is 5 months not pretty short for needing to now get a new one? Any advice? Should I contact framework?
Is your battery rated for 240W PD over a single port? I’ve not found a single battery bank capable of higher than 140W, and even those will often regulate power below their maximum in order to maintain longevity (as they should).
Thank you for the response. I think the USBC cable just got really bent somehow and that’s what’s causing it so I’m just going to get a new usbc cable.
Well now the end just entirely disconnected
Well, I’m not an expert in the quality analysis of electrically conductive materials… but my gut tells me that doesn’t look right.
Jokes aside, it could be the cable. I’ve personally switched to LTT’s “True Spec” cables because of some similar usb c issues I’ve had, but I’ve also used Anker 240W cables (one of which died on me). I’ve been real happy with the LTT ones so far.
I’m assuming your cable is out of warranty.
I have had mine for over 6 months now. It gets plugged/unplugged 1/2 dozen times a day and so far no issues. So yours is either one of the rare cases, or it has been mishandled.
USB C’s are not as robust as lets say one of the large barrel dc connectors that Lenovo used to use, but even they are moving to USB C.
Framework’s USB cable is actually very cheap compared to 3rd party brands. I have a quality one sitting here that cost tripple the amount then what Framwork charges.
The cable should be rated for 240W to get the full power from the charger. USB-C cables have chip in them, which tells chargers the cable spec, so even 240W charger will supply maximum 60W trough the cable without the chip. Looks like that’s the reason of 58W reading in your first message - the connector was loose and the chip wasn’t detected, so charger provided the max allowed power for such case. There are cables marked with 100W and the charger will not supply more than 100W over these cables too.
This may be a sign that you need to clean USB port on the charger. It’s possible that dust accumulated there and blocks the full insertion of the connector, so some lines of the cable are not connected to the charger lines.
Before my framework I had a Lenovo laptop so I had one of those chargers for years without issue so I guess I got to used to not having to be careful about not bending my charging cable. But it’s ok I got an Apple 240w usbc cable since I needed one asap and that is what available. If I wasn’t in a rush I probably would have gotten the LTT cable. R.I.P. stock framework cable June2026-October2026
The new Apple usbc I got plugged in perfectly so maybe it was a probably with the port on the framework usbc
