I just wanted to check that I have understood the situation correctly with respect to the 2nd Gen components introduced with the Gen 2 Laptop 16 and their compatibility with the Gen 1 (7040 Series) mainboards.
As I understand it, most (all?) of the Gen 2 components are compatible with the AMD 7040 Series mainboards, i.e.
- 2nd Gen Top Cover is compatible with 7040 Series Mainboard
- 2nd Gen Keyboards are compatible with 7040 Series Mainboard
However, if you buy a complete 7040 Series laptop (DIY Edition or Prebuilt), there’s no choice offered in terms of the chassis, and you can only choose from 1st Gen Keyboards. I assume the only ways you can get a 7040 Series laptop with upgraded components are either
- Buy a complete laptop and then ‘upgrade’ it with individual parts (which would be very costly and leave you with several unneeded spares)
- Buy all the spare parts individually and assemble the laptop from scratch (It’s great that this is possible, but it’s a lot more work, and you don’t have the benefit of a professional testing the assembled laptop before shipping. Also, RAM is out of stock: presumably they prefer to use their RAM stocks for complete laptop orders)
My dilemma is that on the one hand I don’t want to buy a brand new laptop with a top cover that could be better (because who wants a chassis that flexes more than necessary?), and I don’t really want a windows logo on my linux laptop keyboard either, but on the other hand, I’m not sure why I would want to pay extra for an AI Series processor, since I have no use for the NPU and the 7040 processors should be more than enough for my requirements.
(I do understand that there are economic/logistic considerations: I assume that even the DIY Edition laptops are stocked as a pre-assembled chassis + mainboard, and configuration to the user specification consists of adding the required RAM and peripherals, testing it, then packaging all the bits for shipping. Building the same laptop to order from individual parts would be orders of magnitude more work, and the alternative would presumably involve stocking a larger number of pre-assembled variants)
Have I correctly understood the situation in terms of compatibility and availability?
