Finally got my own Framework 16 for Christmas, and it’s been great. However, just this past week it has stopped taking a charge from my charger. It’s a PPS 300W with 3.3-21V 5A on the main port. I’ve even gone as far as to replace the USB-C cable with a UGREEN 40Gbps cable and unplug everything else from it. Anyone else run into anything similar?
Which OS (Operating System)? Windows 11
Which release of your OS (Operating System / Windows 10, 11)? (if you are having a Linux related issue, please create your thread under the Linux subcategory) Pro 25H2
Which Framework product (Laptop 13, Laptop 16, Laptop 12 or Desktop) and which generation of CPU (Intel 11th gen, Intel 12th gen , Intel 13th gen, Intel Ultra Series 1, Chromebook, AMD 7040 Series, AMD AI 300 Series, AMD AI Max 300 Series) or GPU (NVIDIA® GeForce RTX™ 5070, AMD Radeon™ RX 7700S) Laptop 16 7840HS, no dGPU
Sorry, just to clarify, the power brick itself is capable of 300W total sustained output across its six ports, but only two are rated for 100W at the specification I listed in my OP. There’s also two non-PPS USB-C ports and two USB-A ports, which are out of scope for this discussion.
That’s unfortunate. I’m confident that it was charging successfully from this charger at one point in its life. And it does indicate that it’s connected to power, with the battery percentage effectively frozen (neither increasing nor decreasing) while plugged in.
