96GB mem in FW 13 Pro
Hello,
Laptop is meant to support 96GB of memory AFAIK, but framework is not giving such option when configuring an order.
If user wants 96GB then he/she should order fw 13 pro without memory and buy 96GB memory separately from different shop? is that expected process? any reason why framework does not let user to buy such configuration directly?
anyone tried fw 13 pro with 96GB already? any issues?
I’m not sure I’ve seen a 96GB LPCAMM2 module on sale… heck, at the moment it’s difficult to find 64GB modules in the retail market. So that might be the biggest issue.
I believe that it’s been stated somewhere on here that the device will support it… it was just that they weren’t available in the OEM / retail market, so they didn’t advertise it.
If you order the DIY version of the Framework 13 Pro with an AMD cpu, you can get it with 96 Gigabytes of DDR5 RAM from Framework for only $100 more than the 64 Gigabytes of RAM for the Intel cpu because Framework has a very reasonable price for 96 Gigabytes of DDR5 RAM. Or you can get the DIY model of the Framework 13 Pro with 64 Gigabytes of DDR5 RAM for $390 less than the version with the Intel cpu.
A friend of mine has the DIY version of the Framework 13 with an AMD cpu and he bought a 96 Gigabyte DDR5 5600 Crucial memory kit from B&H Photo Video to install in his new Framework 13 and it works like a charm.
I have a DIY model of the Framework 13 Pro. I only have 32 Gigabytes of Crucial DDR5 5600 RAM and it runs quite fast and very well.
Of the seven friends of mine who’ve bought Framework 13, Framework 16, and Framework Desktop computers all with AMD cpus and they have been very happy with them. All but one of them are running Linux, one is running Windows 11, and the Framework 16 is is dual boot, running Linux on the 80mm M.2 NVMe SSD and Windows 11 on the 30mm M.2 NVMe SSD.
I’ve used AMD cpus to run Linux for 29 years and find that Linux runs very well on AMD cpus.
I agree with the sentiment here, and would argue that most people don’t need the memory speed of an LPCAMM2 module. That’s not to say progress is bad, but in my case, swapping to Intel would have cost me £800 on top of an already very high spend (I went for AMD 64 GB).
Its not particularly difficult to find 96gb lpcamm2 modules on ebay, although youre right in terms of retail they are nowhere to be found. In any capacity, for that matter.
96 GB lpcamm2 modules are available on eBay but they are almost twice as much as the price of 96 GB of DDR5 5600 RAM for a AMD-cpu Framework 13 Pro. 96 GB of DDR5 5600 RAM is also available from eBay but it is more expensive than what Framework charges for 96 GB of DDR5 5600.
I think one of the biggest questions is going to be why do you want 96Gb of RAM.
The answer to that will likely drive the buying choice, because if it is for things like local AI, then surely the memory speed will matter much more, as will how much RAM can be allocated to the GPU.
It would be important to note, neither the Ryzen AI 300 series OR the Intel Core Ultra Series 3 devices are anywhere near as powerful as the Ryzen AI Max+ devices… so sticking 96Gb RAM into either of those devices isn’t going to get you a portable AI powerhouse… but (and I say this as a long-time AMD user both on the GPU and CPU front) at this time, for thin and lights… the Panther Lake is a SERIOUSLY impressive chip. My Framework Pro easily dismantles the GPD Win Max 2 with 8840U I have here… it lasts longer on battery, and outperforms it in gaming and local AI tasks. And the GPD Win Max 2 runs at 7,500MT/s … not 5,600MT/s
If you’re looking for a portable AI workstation, frankly you’d be better looking at something like the Asus Pro Art / ROG Flow Z13 or something similar based on the AI Max+ chipset… just beware that those feature soldered RAM that is not upgradable later and you’re likely to measure battery life in minutes, rather than hours.
If you have a different use case, then of course ymmv.
developer’s workstation for in-memory analytics, not AI.
64GB is barely giving ability to cross 2^32 rows table barrier (5e9 rows, 1 column int32, another float64 is already 60GB) but not leaving much memory required during query execution. I went for intel and faster RAM because mem speed is important to reduce latency, CPU caches are already optimized, as well as SIMD (unfortunately no AVX512 in this CPU).
I would chose 96GB if framework would offer it.
The portability is just a want then not a need. If regularly running analytics with that large of a memory space a desktop workstation is much better suited. Especially one with ECC memory.
There will always be someone looking to max out any configuration, they are usually a small fraction of users though.
Money is not as much of an object when extremes are sought out though.
