A lot of my projects involve GPIO modules and devices that talk over their pins, most of them still in the works. Testing them is a mess right now. Either I flash and set up a Raspberry Pi, find a keyboard and mouse, and connect to it, or I use a Raspberry Pi Pico as a USB-to-GPIO adapter, which works but is pretty janky. I also end up with several Pis lying around, so trying something new means either tearing down whatever’s on the breadboard or leaving a project shelved, Pi and all, until the next one comes along.
For a while I’ve wanted to test and program those little boards straight from my everyday laptop, with nothing extra to set up or pack when I travel. Ever since I saw how plug-and-play Framework’s expansion cards are, I’ve been toying with the idea of a “built-in dongle”.
u/geerlingguy’s reviewoftheArgon40ONEUP pushed me further. It’s nice to have the Pi header on a laptop, but there it comes through USB-C ports that only work with Argon’s own breakout. There’s also rp2350-gpio-card, a nice open design that breaks some RP2350 pins out to pads on the card itself. I wanted the opposite of the ONE UP and a step past the pads: a card that’s plain USB to the laptop, with a normal Pi header I can plug jumper wires into and the software to run existing Python sensor code against it. So I finally spent some tinkering time (and quite a few AI tokens) on it.
What it is:
• A regular expansion card with a small T-shaped head sticking out of the laptop. The head has a standard 2×20, 2.54 mm header with the Raspberry Pi pinout.
• An RP2354B drives the pins and talks to the laptop over plain USB, so there’s no driver to install on Windows or Linux.
• Python drives the pins through Adafruit Blinka, so the existing CircuitPython drivers for sensors, displays and other parts work unchanged. A small bgpio CLI finds the card, shows its info and updates its firmware.
• Everything is open (MIT for software, CERN-OHL-P for hardware, CC BY for docs), so ideas, issues, PRs and forks are all welcome.
It’s early. The card doesn’t exist yet; I’m building the firmware and host tools on a Pico 2 W. It shows up on Windows without a driver, and GPIO works from Python through Blinka; I2C, SPI, PWM, the ADC and the UART are implemented and pass their tests on the bare board, but I haven’t wired real modules to them yet. That’s next: an I2C EEPROM and a few sensors on the Pico to test the protocol end to end, while I route the card’s board in KiCad. After that comes ordering boards.
The picture is a concept render of where I’d like this to go: a card on each side, each wired to its own experiment, and the next experiments waiting on the desk with their cards already wired up, so switching means swapping a card instead of rewiring or digging out another Pi. Today a Blinka program talks to one card at a time, so driving two at once is a long-term goal, not something that works yet.
Also, I don’t own a Framework. They aren’t sold in Argentina, and a new one is out of my budget. I’m working from Framework’s published CAD and testing the electronics through a USB-C extension cable on my current laptop, which tells me nothing about fit. At some point I’ll pick up a used one, but until then I’m guessing at clearances and tolerances, and that’s where I could use some help:
• Framework 16 and 12 owners: could you measure the gap between two neighboring expansion cards? On the 13 the head covers about 2 mm of each neighbor (based on the 10.3 mm community measurement), but I have no numbers for the 16 or the 12.
• Anyone: would a head sticking out like that bother you, say by blocking the neighboring ports or catching on your bag?
• Hardware folks: I’m not an electronics engineer and AI is doing a lot of the heavy lifting on that side. The schematic is in the repo (hardware/card/blusa-gpio-card.pdf), and I’d love a review before I order any boards.
