I just opened up my laptop, taking everything out as I found out my CPU was 15 to 20 degrees hotter than everything else.
I originally took it apart as my GPU stopped being detected on windows. I reinstalled bios 4.05 and it was working again, then I realised my CPU was hotter than everything else. I took everything apart and found out the liquid metal on my CPU has completely hardened, I’ve submitted a ticket about this, and will see how it goes with that. But once I put everything back together, the internal display is not turning on, I cannot connect to external display, no accessories are connecting, I cannot boot into a live boot either.
The laptop power button turns on, the fans start spinning (1 does, the other is kind of broken, a replacement is on the way), but nothing else works. The LED next to the adapter is flashing RED/BLUE and nothing else.
Before I took everything apart because the dGPU crashed on me, the display sometimes flickered and turned off and went to the lock screen. Sometimes this would go to sleep mode, sometimes it would only feel like I switched user. I believe this was a display problem and have a display coming to replace it.
What should I do with this.
