AirPod audio garbled
My issue:
I have a pair of 2nd generation Apple AirPod Pros. They connect to my Framework via Bluetooth very quickly and consistently. But they often have garbled audio. The audio isn’t completely unintelligible but it is very choppy and sounds digitally distorted. Has anyone else experienced this?
If I restart my machine and reconnect again, that sometimes solves the issue.
Setup details
Ubuntu
Which release version?(if rolling release without a release version, skip this question)
24.04.3 LTS
Which kernel are you using?
Linux 6.17.0-14-generic
INSYDE Corp. 03.16 07/25/2025
Framework Laptop 13 AMD Ryzen 7040 Series
Under Sound settings, check that you are using the “Headphones - Airpods” audio option instead of “Handsfree - Airpods”.
Oh interesting! Yeah I think that did it. Just curious: what’s the difference between the two?
Handsfree is for bluetooth voice calls (mono), whereas headphones is for stereo sound/music. Glad that worked for you :slightly_smiling_face:
