Bazzite
Which release version?
Updated right before posting
Which kernel are you using?
6.19.14-ogc5.1.fc44.x86_64
0.0.3.6
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
Framework Laptop 16 AMD Ryzen AI 9 HX 370 with AMD Radeon RX 7700S
Problem:
I had the original Framework 16 with the Ryzen 9 mainboard and unfortunately it spontaneously died on my one day. I ordered a replacement mainboard and updated to the Ryzen AI 9 HX 370 and have been having nothing but problems since then. I had data on it that I wanted to back up so I didn’t reinstall my OS on it right away and was getting weird system hangs until I would hard reset the machine. I figured this was driver weirdness and eventually did the right thing and reinstalled a fresh copy of Bazzite on it completely wiping the drive it was installed on. Even after this, I’m still getting system hangs, and now I’m even getting GPU artifacts doing mundane things like browsing the desktop. They don’t seem to pop up while I’m in game, but otherwise every so often I’ll get rainbow static along the bottom of my display. I’m assuming this is still a driver issue with the mainboard or something since it’s using the iGPU at that point, but I have no idea what else to do. I’ve run firmware updates through Bazzite, everything is up to date, Bazzite it up to date itself, and I’m still having nothing but problems
