Anker 556 Dock Behavior
I have the Anker 556 dock and it’s been working perfect so far, the only issue is that when I connect the dock’s cable to it the laptop needs to be awake (and open since my laptop sleeps when it’s closed) in order to work. Once I’ve done that, I’m able to close the lid, put it to sleep and wake up the laptop fine as long as the cable has not been disconnected (if it has I need to open the laptop again). I am wondering if this is normal behavior and if there is anything I can do or any other dock that would allow me to wake up the laptop from sleep when first connecting it to the dock? I have the Framework 16 and I’m using Fedora 41 KDE. Thank you!
