@reanimus Thanks for the video. Seriously appreciated. That wobble is insane.
I donāt know that it is. I was deliberately flicking the screen around to demonstrate that the screen maintains position. Previously, it would have closed/fallen open.
When walking around with it or the like, it remains stable, and Iām able to type pretty nicely both on my bed and on my lap.
On the new video posted by LTT (time-stamped link) you can visibly see the screen āwobbleā
Granted it is on top of a desk mat, and so I guess screen āwobbleā is likely just going to be a thing.
Thatās so 2014 thoā¦ But the reality of a taller display means a longer force arm, which means easier oscillations.
This is NOT to be confused with weak/loose hinges where the display will just flop down.
Actually the wobble is so massive at 11:04 the camera shot is going up and down. Desk mat certainly donāt help on this regard.
I just finished replacing my original hinges (the laptop was bought in June 2021) with the 4 kg hinges.
The replacement was very easy. The only difficulty I encountered during replacement was that, as I was attempting to install the right hinge, one of the small screws kept being drawn to one of the magnets that hold the bezel in place. I ended up having to hold the screw in place with a pair of tweezers (so that it would not be drawn to the magnet) while I screwed it into place with the tool provided with the laptop.
Once installed, the 4.0 kg hinges are great. Firm but not too firmā¦ very much like the feel of an Apple MacBook. Iām really happy that I replaced the original hinges.
Itās been a long time since I added my own āSaga of the Hingeā to this post. I just replaced my replacement hinged with 4kg version and have two comments.
The 4kg hinges are so much better. My display stays where I put it and doesnāt wobble at all.
FW support has come a long way since May '22. Iāve been working through a failed webcam and they were responsive and helpful in debugging to pin down the source of the problem.
Frameworkās come a long way.
