Hey All,
I went to run updates this morning on my FW13 Pro and came across some apt source issues.
repository 'http://oem.archive.canonical.com resolute InRelease' doesn't have the component 'nantou' (component misspelt in sources.list?)
repository 'http://framework.archive.canonical.com resolute InRelease' doesn't have the component 'burlingame' (component misspelt in sources.list?)
I commented mine out for now. I just wanted to bring it to light in case this is not solely a me problem.
Is it just a me problem?
Details
26.04 LTS (Resolute Raccoon) that came with the FW13 Pro
Which release version?
Skipped, check ![]()
It’s not “A Dell”, it’s a Framework. I’m not rolling in the deep. ![]()
Which kernel are you using?
Linux framework-13-pro 6.17.0-1030-oem #30-Ubuntu SMP PREEMPT_DYNAMIC Thu Jul 16 15:01:53 UTC 2026 x86_64 GNU/Linux
Not updated, stock with the Pro
- AMD Ryzen™ AI 300 Series
- AMD Ryzen™ 7040 Series
- Intel® Core™ Ultra Series 1
- 13th Gen Intel® Core™
- 12th Gen Intel® Core™, 11th Gen Intel® Core™
- Other (Intel® Core™ Ultra Series 3)
