I have some issues with my Linux, i never seen it to go to suspend mode, and i see kernel dmesg messages whenever i do suspend or lock, it is doing logout and kill all windows.
Also display is always bright, whenever i close the lid, and open it slowly i see light, it looks that display is always on with login screen, its why battery drain so fast whenever i lock it or suspend.
Can someone please suggest what i can do?
I followed all discussions but nothing helps.
Kernel Options:
iommu=soft nvme_load=YES acpi_osi="Windows 2020" quiet splash mem_sleep_default=deep
Kernel Modules:
options i915 enable_psr=0
│ File: /sys/power/mem_sleep
1 │ s2idle [deep]
│ File: /etc/systemd/sleep.conf
15 │ [Sleep]
16 │ AllowSuspend=yes
17 │ AllowHibernation=yes
18 │ AllowSuspendThenHibernate=yes
19 │ AllowHybridSleep=yes
20 │ SuspendMode=suspend
21 │ SuspendState=disk
22 │ HibernateMode=suspend
23 │ HibernateState=disk
24 │ #HybridSleepMode=suspend platform shutdown
25 │ #HybridSleepState=disk
26 │ #HibernateDelaySec=180min
