Audio Expansion Card relevant for 13 Pro?
I’m about to upgrade my Framework 13 7040 to the 13 Pro AI 9 370. Will I still benefit from the Audio Expansion Card?
I don’t regret that I didn’t buy the Audio Expansion Card. For me is the embedded jack good enough and I would not waste slot for other one. But If you have it than test it and share what you found.
I think the promise of the audio expansion card is that it has a better DAC than the stock one. However, if you are after audiophile quality, and don’t mind a dangling widget, I’d advise getting a branded unit from Chord, Lehmann Audio, FiiO, Shanling, etc.
This is only worthwhile if you have a very good pair of headphones/IEMs - what do you have?
I’m waiting for the latest Sony or Bose noise-cancelling headphones to come out. Although both excel at noise-cancelling, I don’t think they are considered audiophile headphones.
