Whenever the charger isn’t plugged in, iTunes audio seems to pop and crackle as audio does when I’m running something memory-intensive (I don’t know how else to describe the problem), even though that isn’t the case. I don’t think I’ve noticed the same audio bug with other programs. Does anyone else experience this or know of actions I can take to diagnose the problem?
I’m not terribly tech savvy, so thanks in advance for being patient with me.
You mean the sound as if there were short, silent gaps in the audio?
If this happens on Windows then it’s a common issue with that system and it’s related to what’s called Deferred Procedure Call latency.
You can confirm that this is the case using LatencyMon:
Occasionally it’s just e.g. one bad driver clogging up the entire system like that, causing those pops. The worst I had was back in the Windows 7 era, when audio would crackle and pop during startup.
It does sound a bit like when I encounter gaps in an Audacity waveform, and it did happen on Windows. I’ll check it using the software you’d provided. Thank you!
