Battery Charge Limit and Custom Fan Curves Desktop (Linux)
I see there are a couple of projects started for custom fan curves:
and
I’ve also started a project with an easy to use UI to control the fan curve, max TDP and battery charge limit called fw-helper.
Project is here: GitHub - Wooloomooloo2/fw-helper: Control your Framework 13 Pro's Power use, charging and fans without going to the BIOS · GitHub
There is AI code, so please check if you’re OK with that before opening. It pretty much works on the Intel FW 13 Pro:
  • Battery limit works (down to 60%)
  • Fan curves work and can be saved with profiles
  • TDP limit works down to 8w
  • Max TDP set of 25w allows 32w sustained
