Battery health is down to 70% after just six months
Hello, I’m reaching out because I’ve just hit 80 charge cycles (according to my resource manager), but my battery health is already down to 70%. I’m not sure what to make of this scan—it initially showed 108%. I can feel that the battery doesn’t last as long as it used to, but I’m not really sure what I should do…
How old is the battery? Some methods of counting discharge cycles only complete full ones, and so 80 would be quite a lot.
Does 80 cycles seem like a reasonable number for your use?
It is a known issue (reported to FW in Jan) that the ACPI battery cycle count (Exposed at /sys/class/power_supply/BAT1/cycle_count, and used by most generic system monitoring tools like Mission Center) is incorrect for Framework batteries after 255 cycles due to an ACPI implementation bug. The field size is too small, effectively reporting correct_count % 256 (or something slightly different on the 16"). You can read the true value from the EC with either # ectool battery or # framework_tool --power -vv (from extra/framework-system on Arch). The BMS counter should be trustworthy.
It’s also a good idea (especially if you set a charge limit) to run a battery calibration to be sure the capacity (health) measurement is accurate.
These should give you a more accurate read of the state of things to evaluate if your battery is indeed out of spec.
As far as I’m aware, the standard implementation (and what FW’s BMSs do) is to count cumulative level change rather than discrete full cycles. Thus [100% → 0% → 100%] is 1 charge cycle, as is [50% → 55% → 50%] repeated 20 times.
I had the pc for 6 month and I use it to take my note in classe + watch video some time…
I’ll try the recalibration
welll i did the recalibration thing and well… the full recharge is still 80…
Some time ago there was a BIOS update that was vital to make sure that your battery health wouldn’t be badly impacted… IDK if that’s related to what you’re experiencing, maybe it was longer ago than that, but it wouldn’t hurt to do BIOS updates to be sure. You could also check with FW support about it, they would know more about the details.
(Modern laptop batteries do degrade pretty alarmingly quickly. 70% after six months does sound a little low yes but it’s not as crazy out-of-line as it sounds. Unless I’m traveling I have my FW BIOS set to top the battery out at 80% so it’ll last longer, because I’ve had laptops where the battery got degraded pretty badly after a while.)
For the bios I’m always trying to keep at last version (I’m at 4.5) but I should turn on the charge limit
Given that the cycle count hasn’t increased, it seems you’ll have to get the real value from the EC with one of the tools I mentioned before. 70% after 6 months would be pretty fast, but nothing definitive can be said without knowing the actual cycle count. For reference, Framework targets 80% after 1000 cycles.
That is probably the way to go, one of the downsides of always using a charge limit is that the bms never gets the chance to “recenter”.
Compared to mine, thats definitely high
Seen the same thing on my framework. I know its been 2 years, but I run it basically plugged in as much as possible, and I cap battery to stop charging at 80%, which should be ok.
It’s also been 2 years, but still.
Device Name: FRANDBA
Manufacturer Name: NVT
Serial Number: 0375
Unique ID: 0375NVTFRANDBA
Chemistry: Lithium Ion
Designed Capacity: 85001 mWh
Full Charged Capacity: 74474 mWh
Wear Level: 12.4 %
Cycle Count: 138
I know battery degredation is kind of logarithmic (fast at beginning, slower as it progresses). 12.4% for 138 seems high.
Do you always keep your battery topped off at 100%(or dead at 0%)? From looking at the “battery charge over past week” it seem fairly … questionable.
Though degrading 30% from just sitting at 100% for 6 month still seem .. questionable. But it is a 7040 series. This thing runs quite warm, depend on what you are doing.
Looking at the picture posted, letting any battery go completely flat (close to 0%) regularly is the fastest way to degrade it.
So if the OP regularly kills it or lets it get to the 10% range (this seems to be common among young people lately for some reason) that is going destroy whatever chance it had at maintaining its capacity.
In the same likeness keeping it constantly charged to 100% is also not good for a battery physically either with this chemistry.
:index_pointing_up:
Keeping the battery between 20% and 80% as much as possible is the best way to maintain its longevity apparently.
Is there a way to ensure this? I often leave mine plugged in so it goes straight to 100% and stays there. I haven’t seen anything in Fedora settings to limit the charge ceiling.
This is not right. A 99% battery shouldn’t be charging at 55.0W
The voltage, 15.7V, is much less than 84%, the real percentage should be 65-70%
The displayed battery percentage is much higher than the battery’s actual percentage, resulting a lower calculated battery health.
It’s recommended to continue charging for at least 3 hours after full to re-calibrate the “fuel gauge”. Then use as normal
Go into the BIOS, turn off battery management or whatever it is called in that screen.
Below that should be an option to limit the charge state. Set it to 70%. (Or 80% if that extra time is necessary) Save and exit the BIOS.
