@Michael_Lingelbach
The only thing I changed in the bios was turning PS/2 Mouse Emulation? From auto → disabled (iirc) when I first got the laptop diagnosing touchpad issues, and left it like that. Oh and setting up the EFI boot sequence!
Hardware:
- CPU: DIY 1165G7
- Memory: 16GB (2x8GB SK Hynix 2400MHz sticks from an old Dell XPS 15 9550)
SSD: 512GB (LITEON CA3-8D512 from an old 2018 Huawei Matebook X Pro)
WIFI: AX210 from Framework
2.8W was recorded under:
- Fedora 34
- Gnome 40 for a standard/baseline, extensions disabled (though
- powertop --auto-tune (all tunables set to good)
- power-saver profile using power-profiles-daemon
- No expansion card connected
- PSR disabled
- 5% display brightness
- Keyboard backlight off
Note, I primarily use Sway with Waybar (1.6.1-3, wlroots 0.14.1-2 pulled from F35 repo). Though I think Waybar and/or my config is drawing some unnecessary power, so Sway alone with no Waybar seems to consume similar to Gnome 40. Gnome 40 seems to be pretty power efficient, shrugs
Surprisingly, removing the AX210 card entirely vs. being connected to my wifi (though I’m right by my wireless AP) seemed to make negligible difference in power consumption.
I just checked, with Sway/Waybar + Microsoft Edge Beta, 5 tabs of the Framework forum ;), and powertop, I idle in the low 4W. Note in my Waybar at the top, cpu frequency is wrong. The battery current is correct and usually matches up with powertop, but it’s set to a lower refresh interval so I can keep an eye out on battery drain, for now. I think it spiked when I went to screenshot, or something. Edit: display brightness at 30%, speakers at 75%, wifi connected, bt on but not connected to anything.) Edit 2: I’m pretty sure powertop’s reporting of nic:virbr0 is incorrect.
Edge is currently running off XWayland, might be more efficient with native Wayland.
I think with regular browser usage, with a fair number of tabs, I idle maybe 5-7W?
I can give concrete numbers later, and also test with Firefox, XWayland and Wayland. Are there any websites you’d like me to open and keep idle for testing purposes?
Also, for video playback, hardware encoding and VA-API make a pretty substantial difference, about 1-2W less with a 1080P file. 30% brightness, 75% speakers with Wayland MPV + VA-API, I saw around ~6-6.5W during playback (iirc). Got around the same in Windows 10 using the default media player, same file.
Note: power-saver profile with power-profiles-daemon seems to make a huge difference, and it also seems to cap max frequency at 1600MHz.
I haven’t really done much real-world usage testing (and it really depends on my workflow/what I’m doing), but from the last few days tinkering/testing, I’d estimate I can get around the same battery life as Windows 10 just looking at discharge rates, or perhaps more (perhaps less). Fans seem to spin up less in Fedora – I don’t plan on using Windows for an entire full battery discharge, but I can test if anyone needs.
Edit: @Michael_Lingelbach, just double checking, do you have any rogue tasks taking up cpu cycles? I had this happen to me, and came across a fix:
https://www.reddit.com/r/Fedora/comments/ou7809/random_cpu_spikes_kworkeru162events_unbound/?utm_source=amp&utm_medium=
Basically, I saw that kworker/u16:X+events_unbound was causing like 99% usage on a thread randomly, eating up battery. sudo btrfs balance / + a reboot seemed to have fixed it, though.
Whew, that was a lot of stuff, might be messy cause I just kinda dumped all this. I have numbers written down that I plan on (hopefully) putting together, and doing another run through – hope this helps!
As for powertop2tuned, are you sure that setting is actually working? I did that in powertop tunables, with:
echo 'auto' > '/sys/bus/usb/devices/3-4/power/control'
And it seems like it does nothing. Hm, maybe I need to persist the setting, and reboot…
Have you tried physically disconnecting the HDMI expansion card and seeing if it makes a difference? I’m going to try powertop2tuned, thanks – will report back!
