Which Linux distro are you using? Fedora
Which release version? 44
Which kernel are you using? 7.1.7-200
Which BIOS version are you using? 3.20
Which Framework Laptop 13 model are you using? 11th Gen Intel® Core™
This is an issue I’ve noticed occasionally over the last few months. I’ll be working, my battery will show at some normal percentage (anywhere from 30%-90%), and then suddenly the interface claims to be at zero. Fedora will switch to power saving mode, sometimes it will immediately hibernate and I’ll have to push the power button. But then… nothing. It’s clearly not actually dead. I tried running upower -i /org/freedesktop/UPower/devices/battery_BAT1 and I see this:
native-path: BAT1
vendor: NVT
model: Framewo
serial: 00BE
power supply: yes
updated: Wed 19 Aug 2026 10:03:22 AM EDT (22 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: action
energy: 0.0154 Wh
energy-empty: 0 Wh
energy-full: 55.0088 Wh
energy-full-design: 55.0088 Wh
voltage-min-design: 15.4 V
capacity-level: Low
energy-rate: 13.1824 W
voltage: 14.94 V
charge-cycles: 248
time to empty: 4 seconds
percentage: 0.0279955%
capacity: 100%
technology: lithium-ion
icon-name: 'battery-caution-symbolic'
History (rate):
1787148202 13.182 discharging
1787148172 13.922 discharging
1787148142 14.553 discharging
1787148112 13.968 discharging
History (voltage):
1787148202 14.940 discharging
1787148172 15.429 discharging
1787148142 15.342 discharging
1787148112 15.343 discharging
This is while I’m actively plugged in, too. (And I can confirm it’s been more than 4 seconds since I ran that command!)
Any ideas for what’s going on here?
