Bazzite
Which release version?
44.20260629 No idea if Bazzite is rolling or not.
I updated today (7/11/2026)
Which kernel are you using?
Whatever comes with Bazzite.
4.01
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
AMD Ryzen AI 9 HX 370
I am trying to get hibernation to work on my FW16 running Bazzite. I have followed the guide here: Using Swap for Additional Memory or Hibernation - Bazzite Documentation
After following that guide, the system will hibernate (as far as I can tell) but it will not resume. If I run “dmesg | grep hibernat” I see there is a message about “image mismatch” followed by “Failed to load image” and then “resume failed (-1)”.
Is there anything more I need to do to get this to work?
