Bluetooth - bluez downgrade
Fedora
Which release version?
42
Which kernel are you using?
6.14
3.03
AMD Ryzen™ AI 300 Series
I got my FW13 last week. Fedora 42 worked fine out of the box, until software update ran, which broke bluetooth (wouldn’t even turn on in settings). I had to downgrade back to bluez version 5.80 (sudo dnf downgrade bluez) to restore functionality.
Just posting in case this helps anyone.
