[RESPONDED] Boot Failure after firmware update
My laptop has an Intel Core i5-1135G7 and was running KDE Neon with the latest Ubuntu LTS underneath. I was just adjusting power / performance settings with TLPui according to the guide on Increase and Optimize Linux Laptop Battery Life
and then I tried updating firmware via Discover, then when I tried to reboot my laptop it got most of the way there then got stuck at this message
[ 0.869355] ACPI BIOS Error (bug): Could not resolve symbol (SB.PAGD. STA… OSI), AE NOT FOUND (20220331/psargs-330)
0.869378) ACPI Error: Aborting method SB.PAGD. STA due to previous error (AE NOT FOUND) (20220331/psperse-529)
0.8886251 pci 0000:00:07.01 DPC RP PID log size o is invalid 0.889428) pci 0000:00:07.11 DPC: RP PIO log size o is invalid
0.890291) pci 0000:00:07.2: DPC: RP PIO 10g size o is invalid
0.891032) pci 0000:00:07.3: DPC: RP PIO log size 0 is invalid
0.919936) ACPI BIOS Error (bug): Could not resolve symbol (SB.PAGO. STA. OSI, RE NOT FOUND (20220331/psargs-330)
0.919944) ACPI Error: Aborting method SB.PAGD. STA due to previous error
(RE NOT FOUND) (20220331/psperse-529)
t 0.990358) ACPI BIOS Error (bug): Could not resolve symbol (SB.PAGD. STA.
OSI), RE NOT FOUND (20220331/psargs-330)
t 0.990367) ACPI Error: Aborting method SB.PAGD. STA due to previous error
(RE NOT FOUND) (20220331/psparse-529)
1.699900) ACPI BIOS Error (bug): Could not resolve symbol (SB.PAGD. STA.
1.699420) ACPI Error: Aborting method SB.PAGD. STA due to previous error
I 1.739209) ACPI BIOS Error (bug): Could not resolve symbol [SB.PAGD. STA.
1.739286) ACPI Error: Aborting method SB.PAGD. STA due to previous error
1.760870) ACPI BIOS Error (bug): Could not resolve symbol SB.PAGD. STA
1.760949) ACPI Error: Aborting method SB.PAGD. STA due to previous error
You are in emergency mode. After logging in, type “Journalctl -xb” to view
system logs, “systemctl reboot” to reboot, “systemctl default” or “exit” to boot into default mode.
Press Enter for maintenance (or press Control-D to continue):
Ive tried a lot and havent got far. I tried resetting uefi settings and installing the BIOS 3.17 EFI Shell update from a usb stick. It went through and Im right back to that same error message.
If this has already been addressed, I havent been able to find it unfortunately. Any help fixing this would be greatly appreciated.
Update. I was able to get this output:
root@hal:"# Journalctl -p 3-xb
Jun 02 22:16:46 hal kernel: ACPI BIOS Error (bug): Could not resolve symbol _SB.PAGD. STA. OSI], AE NOT FOUND (20220331/psargs-330) Jun 02 22:16:46 hal kernel: ACPI Error: Aborting method SB.PAGD. STA due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
Jun 02 22:16:46 hal kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid Jun 02 22:16:46 hal kernel: pci 0000:00:07.1: DPC: RP PIO log size 0 is invalid
Jun 02 22:16:46 hal kernel: pci 0000:00:07.2: DPC: RP PIO log size 0 is invalid Jun 02 22:16:46 hal kernel: pci 0000:00:07.3: DPC: RP PIO log size 0 is invalid
Jun 02 22:16:46 hal kernel: ACPI BIOS Error (bug): Could not resolve symbol _SB.PAGD. STA. OSI], AE_NOT_FOUND (20220331/psargs-330) Jun 02 22:16:46 hal kernel: ACPI Error: Aborting method SB.PAGD. STA due to previous error (AE_NOT_FOUND) (20220331/psparse-529) Jun 02 22:16:46 hal kernel: ACPI BIOS Error (bug): Could not resolve symbol _SB.PAGD. STA. OSI], AE NOT FOUND (20220331/psargs-330) Jun 02 22:16:46 hal kernel: ACPI Error: Aborting method SB.PAGD. STA due to previous error (AE_NOT_FOUND) (20220331/psparse-529) Jun 02 22:16:46 hal kernel: ACPI BIOS Error (bug): Could not resolve symbol _SB.PAGD. STA. OSI], AE_NOT_FOUND (20220331/psargs-330) Jun 02 22:16:46 hal kernel: ACPI Error: Aborting method SB.PAGD. STA due to previous error (AE_NOT_FOUND) (20220331/psparse-529) Jun 02 22:16:46 hal kernel: ACPI BIOS Error (bug): Could not resolve symbol [SB.PAGD. STA. OSI), AE_NOT_FOUND (20220331/psargs-330) Jun 02 22:16:46 hal kernel: ACPI Error: Aborting method SB.PAGD. STA due to previous error (AE_NOT_FOUND) (20220331/psparse-529) Jun 02 22:16:46 hal kernel: cros-usbpd-charger cros-usbpd-charger.2.auto: Unexpected number of charge port count Jun 02 22:16:49 hal kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02 Jun 02 22:18:16 hal systemd[1]: Timed out waiting for device /dev/sda1.
Jun 02 22:16:46 hal kernel: ACPI BIOS Error (bug): Could not resolve symbol [SB.PAGD. STA. OSI], AE_NOT_FOUND (20220331/psargs-330) Jun 02 22:16:46 hal kernel: ACPI Error: Aborting method SB.PAGD. STA due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
Subject: A start job for unit dev-sdal.device has failed
Defined-By: systemd
Support: Enterprise open source support | Ubuntu
A start Job for unit dev-sda1.device has finished with a failure.
The job identifier is 61 and the job result is timeout. Jun 02 22:20:06 hal systemd[1]: Timed out waiting for device /dev/sda1. Subject: A start Job for unit dev-sdal.device has failed Defined-By: systemd Support: http://um.ubuntu.com/support
A start job for unit dev-sde1.device has finished with a failure.
The job identifier is 1109 and the job result is timeout. root@hal:"#
Hi @Alex_Jeschor welcome to the forums,
can you try booting to ubuntu live usb and update firmware from there?
let’s see if ubuntu live usb gets booted and when firmware updated, try booting on SSD again. cheers :slight_smile:
