Framework 16, 7040 series with the 7700S installed. Running recently upgraded Kubuntu 26.04 (w/ KDE Plasma). Kernel 7.0.0-34.generic. I dual boot Windows, where brightness controls work, so there’s an issue with Linux itself.
I’ve tried editing /etc/default/grub with different params (acpi_backlight=native, i915.enable_dpcd_backlight=0, amdgpu.backlight=0, and other configs), nothing has been working.
cat /sys/class/backlight/amdgpu_bl2/bl_power always outputs 0. /atual_brightness is always 13339. /brightness ranges from 1 to 65535 based on what the UI says is the brightness.
I recently ran amdgpu-install to get ROCm and graphics SDKs, not sure if this may have caused this issue.
There’s no indication of errors at least from journalctl. Is there a lingering known bug with backlight control in kernel 7, or is there something else that could be causing this issue??
