CachyOS
Which release version?
8/10/26
Which kernel are you using?
7.1.8 (I believe? Not at my computer right now to verify, but it was updated just yesterday so it’s up to date)
3.06 (I had previously updated to the 4.01 but had issues even using my bios where selecting anything just rebooted the computer. In addition some expansion card issues, so I rolled back)
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
AI 370
Hey all,
Not so much seeking support, just wanted to get some opinions and feedback. I’ve been running cachy for a while now and was using the standard stable mesa drivers since install. I recently did some reading and discovered it may be beneficial to use the mesa-git drivers since I am using newer hardware (300 series cpu and external 9070xt). I went ahead and installed mesa-git seemingly fine, but haven’t had much time to test (plan to do so more over the weekend after work). My general setup is for gaming, so I was hoping the possible change to “bleeding edge” drivers might make a difference. What are others’ experiences between the two? Did I make a correct choice based on my hardware? I understand git is development and could cause some bugs because it’s not as reliable as the stable, but just wanted to hear some input from the community. Thanks in advance!
