Can you use lower a wattage charger on the Framework 16?
I didn’t wait more than 5 maybe 10 seconds when testing my smaller chargers, it could be the same situation for me.
I almost exclusively use an Anker Nano 20W charger. For pedestrian use, it’s generally enough to keep the battery steady, if not slowly charging. Unless I’m running Windows…
of course, it’s just a slower charging rate, and if you are running the laptop underload, it may draw from the battery incrementally depending on the power draw so its not sustainable like that. For most tasks however you should be just fine, only the real heavy power draw will demand the full 180 wattage
