Hi,
My laptop 16 has stopped accepting charge on the left side in ports 1&2. Tried several USB-C modules, all work in the right side but not on the left. and even a simple USB-A module also does not work when i plug in a mouse ?
Is this a main board problem ?
Which Linux distro are you using? Fedora 44
Which release version? latest
Which kernel are you using? Linux 7.0.11-200.fc44.x86_64
Which BIOS version are you using? latest
Which Framework Laptop 16 model are you using? AMD Ryzen™ 7040 Series with GPU 7700s
