I’ve got some pretty irritating coil while, even at idle. It’s the same whether I have a GPU installed or just the shell with the M.2 board. Oddly, it seems to lessen when I switch from an EPR charger to one without (tested 180W, 140W, and 60W), and is not present when on battery. Any ideas how I could fix this?
It sounds crazy, but it’s worked pretty well for me over the years
Just need to ID the parts on the board which are emitting the whine first
How long have you had your FWL16?
Coil whine can be a real pain. And be really hard to tolerate at times. I don’t know how significant your coil whine is, and I don’t know where the line is for “too much”, but you might want to assess if it could be clearly too much & something you can record.
If you have a popular flagship phone, I think the microphones in some of them have been characterized to the point where you might be able to install one of the better decibel meter apps and it may give somewhat accurate results. Not sure if coil whine is usually at a frequency that phone mics are good enough at to pick up well, but worth a shot I think!
So I’d suggest posting a video of the coil whine, presuming you can capture it. See if you can get it the register with a decibel meter. And then contact support with those.
If you are still within the return window, heck, I’d consider it. Coil whine can drive some people nuts. And I might be one of them.
Working through things with warranty support can involve some time and effort, so certainly you might just prefer to try to solve it on your own. I’d suggest an electronics-safe latex type glue or silicone. A silicone which smells like vinegar, is not safe, not neutral-cure. If you open some power supplies you’ll see that manufacturers often use a rubber glue (potting compound) around inductors & some capacitors which are problematic, to dampen their noise. USB power supplies are a place I’ve seen it most recently I believe.
Ideally it should explicitly say electronics-safe.
One of the top 5 manufacturers of power inductors:
coilcraft.com/en-us/faq
During testing of our board, there is a buzzing sound from one of your inductors. Is this normal? Can it be eliminated?
[…] Applying a dampening material (electronic-grade encapsulant, potting compound, etc.) may decrease the sound level produced
Might have to try that. It is out of warranty, so not like I have anything to lose.
I’ve had it since late 2025. The whine started days after my warranty ended, so it would appear that I’m SOL on that front ![]()
I’ll have to try recording it when other things are quiet enough.
