Computer not starting, no signs of life
The computer suddenly stopped working, in the middle of the night. When the power cord is connected, there is a slight ticking noise every second or so. There is no reaction at all upon pressing the power button.
I tried to contact the support, but the form would not submit succesfully.
Any help appreciated
Ctop
Did you try disconnecting the computer from the mains? And waiting a couple of minutes and reconnecting it to the mains? If so it seems like a power supply issue. Is the ticking noise emanating from the power supply?
Thanks for your advice. I am connecting through a backup power battery. I will try to connect directly and see if that changes anything.
It might be worth explaining more about this. Most people connect their Desktop to the mains, utilising the internal power supply unit. Are you supplying low-voltage power to the mainboard directly? Or is this a UPS that is stepping up to your local mains voltage?
Try again, but take a screenshot of the problem please. Post the image here.
OK, I tried it again, unsuccessfully. Here are the images of the form and the result (images deleted per request from @catastrophic
No, this is a normal power, which will kick in for emergencies like power cuts. It provides the usual voltage to the connected devices.
I now also tried to bypass this and connect to the outlet directly, but there is no change, the result is just as described: The machines shows no signs of life.
I have a random guess. Does this backup power output square wave or modified sine wave? If so, the waveform can confuse or overload the power factor correction (PFC) of the PSU, causing damage
Hm. I used this for four months in this configuration without issues. Now the machine is like a dead brick even if I bypass the backup battery. So my conclusion is that this is unrelated to the current problem.
do you have a spare PSU? the clicking sound feels like hardware failure before BIOS, like it tries to start a fan or close a relay but fails again and again.
No, I dont have an extra PSU. But my hunch is quite similar, it sounds like a very basic HW problem. What kind of PSU would I need and how to get it?
The best way is to RMA, try sending e-mails directly to the stuff or mention them in this topic. I think the problem is from the PSU because the computer generates a ticking sound before pressing the power button. a standard PSU for a desktop computer should be good
Thanks for the image. In that form, it looks like the Product Issue Selection drop-down was not selected.
I recommend with all lengthy web forms, the pieces are copied out to a semi-permanent document on your computer, so if you lose the information, you can copy-paste it again easily.
Perhaps @catastrophic can take a peek at that form snapshot and advise what the issue might be?
Well, the Selection drop-down was not marked as required. Most of the time, I did use it, but after repeated submissions, I started to vary some answers to see if that might get the issue unstuck.
BTW, your advice about semi-permanent documents is well taken (and observed here), but this specific form is mostly drop-downs or very short items, so a copy-and-paste approach does not help a lot.
Anyway, I am looking forward to advice on how to get the issue resolved.
weird, is this still happening? i’ll flag it to the team if so
also please delete this image/comment and repost with your PII removed
checked with the team, see if selecting an issue here resolves it (see image) if not email support@frame.work directly
