Heavily considering the 13 pro with Core Ultra X7 358H. I plan to main Linux despite being a pure noob. I don’t fully understand drivers / kernel versions, so plain-language would be much appreciated.
If you’re running this setup,
- What works and what doesn’t? I’m thinking of graphics/iGPU, Wi-Fi, Bluetooth, touchpad, sleep/wake. Anything currently require manual fixes?
- Which distro + kernel version are you on? Have any update “broken” something? Is there a version to pick or avoid outright?
- How’s gaming? Does XeSS upscaling work on Linux yet? Any experiences with CS2 working/not? Some replies in this previous thread suggested AMD due to its Linux support maturity. Is this still clearly the case, or has Panther Lake been catching up?
- Fans, heat, battery: any problems or tweaks?
Would really appreciate any information and replies. Thank you all.
I switched from Windows 11 to Fedora 44 (with KDE desktop) full-time when I got my 358H back in July, and have not had any major issues so far. I don’t play too many games, so I can’t tell you much there. Minecraft runs beautifully out of the box (see: FW13 Pro Ultra 5 325 vs Ultra X7 358H - real-world battery, noise & heat - #2 by David_Benepe ), as well as Age of Mythology Retold. I did have to make some tweaks to get Red Dead Redemption 2 to work though, because of some issue with intel drivers I think? I have not played any games with XeSS I believe, so can’t tell you anything there. You can hear the fans under full load, but it is a LOT quieter than the fan that was on my intel 1240p mainboard. Battery is significantly better with this new board, although my old 55Wh couldn’t be recognized for some unknown reason (It only happened to me as far as I know). Framework sent me a new 61Wh battery which works perfectly. Can be a little toasty on the bottom, but it has never been an issue for me personally.
I’m on Fedora 44 (KDE variant) on my desktop, and just installed it on FW13 pro X7 358H.
Current kernel is 7.2.13, Fedora tends to follow kernel updates much faster than some disto focusing on LTS support, such as Debian or Ubuntu.
I’m not gaming, so I can’t really comment on that part. The machine is very snappy, but B390 is not to be compared with recent RTX cards, more like a 3050 or maybe a 4050.
So far, nothing is broken.
wifi works, including wifi 7 MLO mode
bluetooth works, tested with mouse and headset.
touchscreen works
touchpad works, including haptic feedback
thunderbolt works (CalDigit TS4 docking station tested), thunderbolt protocol correctly implemented through the USB-C expansion cards.
B390 iGPU is supported
thermal sensors are supported, I couldn’t push the machine enough yet to hear the fans.
Can be improved:
built-in speakers are a bit meh… The software provided by Framework for Windows seem to tune the sound a bit, under linux you can use easyeffects with some framework specific profile, better than out of the box but not the best I had.
Not tested yet:
NPU
Battery optimization (OK out of the box, but far from the claimed 20 hours)
At the moment we only have basic XeSS under Linux… this will hopefully change in the next few months as Intel have submitted PRs into multiple projects to unlock access to the XMX cores within Arc GPUs (including the B390 within Panther Lake CPUs) so we should get access to more speed and better quality upscaling soon.
Thank you for the info. This is kind of exactly what I was curious about (how Intel’s team has been progressing, or if they have. Good to hear there’s at least submitted/proposed progress)
Thanks for all of the details and direct answers. Good to know nothing is inherently broken and that graphics/gaming is just dependent on driver support/progression which seems to be occurring.
Have you found a profile that has worked well for you?
I have tried some of them but either the volume was wavering or there was kind of a static noise in the background.
I am also looking into using this but with only 16Gb RAM this might have to wait a few years till memory prices come down. If you do try/get this to work let us know please!
I have found that with med-high usage so not like gaming all day but many other things going on I will get around 7Ish hours of continuous use so far, better than any other laptop I have tried especially on Fedora KDE still trying to optimize my usage.
The speakers are what they are, so no magic, but still much better. I saw that in the Windows drivers bundle framework provides Dolby software with some interesting profiles, maybe some reverse engineering from those can help.
Some update, as I just started playing with Fedora 45 KDE Release Candidate, which comes with KDE 6.8.1 (I didn’t test this in F44) :
Fingerprint reader works out of the box with KDE (Settings → Users → [your account] → Configure Fingerprint authentication). Note that this only works to unlock/sudo, not for initial authentication.
For moderate usage, battery life is not that bad. As @Digital_Peer said, better than any other laptop I used with Fedora KDE. For light mail/office/surfing, I see about 12 hours autonomy, not too bad.2
7.7 watts/hour while streaming 4K video via Jellyfin, with a few background processes (Nextcloud sync, bitwarden, thunderbird with 3 accounts, firefox with a few tabs open), with screen brightness at 30%
5.5 - 6.0 watts/hour for light usage (same, without Jellyfin streaming)
With screen brightness at 100%, add +/- 3 watts/hour, still reasonable.
As expected, Local AI on CPU/GPU consumes a lot of power. Running small/medium models via LM Studio consumes 30 to 35 watts/hour, so don’t expect more than 2:30 hours of battery life, for +/- 23 tokens/second with small model such as gemma-4-e4b and merely 5 tokens/second on bigger model such as gemma-4-31b.
