Hello, non-technical user here
I have a Framework 13 (first generation
) and loving it, but I am getting into video editing and wondering if upgrading to a 13 pro would allow me to use Da Vinci Resolve, or if I definitely need a Framework 16 for this.
What OS are you running? Should work on Windows, Linux can be finnicky.
Linux Fedora 45 ![]()
Oof, yeah that’s going to be trickier. I’m sure you could fiddle with libraries and eventually get it working but it would be labour-intensive. At that point I would just run it in a virtual machine running Rocky Linux where it’s natively supported.
Got it, thank you. I may decide to dual boot windows just for Da Vinci then. So just to be sure, in terms of resources, the 13 Pro will be good? It looks like it doesn’t have a GPU but I guess if its CPU is good enough for local AI use, it’ll be good enough for video editing, right?
I don’t use DaVinci Resolve and don’t own 13 Pro, but this was briefly discussed in a Reddit post. One of the responders had the following to say:
Speaking as a video editor here. Don’t expect the world out of the 13 Pro for video editing. The integrated Arc B390 graphics on the X7/X9 chips are quite good, but keep in mind that it’s roughly the performance equivalent of an entry-level desktop GPU.
DaVinci Resolve LOVES GPU cores and RAM. Once you start doing more advanced things in Resolve like noise reduction, magic mask, heavy color grading nodes, etc., you’ll really start to see the limitations of the B390. Also, these days, I consider 64GB to be the baseline amount of RAM to be running advanced Resolve projects in. Unfortunately, the LPCAMM2 memory that the 13 Pro’s Intel boards use is devilishly expensive right now. You can only buy 64GB LPCAMM2 from Framework in a DIY build and it’s a $1,600 (!!!) part right now.
Honestly, a FW16 equipped with one of the RTX 5070 GPU modules would fare much better in Resolve. The price differential with LPCAMM2 vs. standard DDR5 SODIMMs is so bad right now that it’s actually not much more expensive to get a FW16 with a 64GB of RAM and RTX 5070 8GB module. Keep that in mind.
Link: Reddit
I’m sure the FW 13 Pro would run Davinci Resolve. As long as your projects weren’t too elaborate, you’d probably get okay performance in the timeline, though if you added GPU intensive effects and processing, the timeline might start to lag a bit. High resolutions, lots of clips, and processing/effects would likely cause the timeline to get a little slow.
The other thing would be rendering. Once again, if you had a lot of GPU intensive effects, rendering would be much slower than if you had a powerful, dedicated GPU.
I think it comes down to your expectations and how involved you want to get with color grading and processing, vs. just some basic editing, cutting, etc. If you want to just start cutting together some clips and maybe tweaking the color and audio a bit, a 13 Pro would probably do fine. But if getting into video editing means diving into heavy grading, effects, 360 stuff, multi-cam, high resolutions, etc., then you’ll probably end up wishing you had more GPU grunt.
For context, once upon a time I edited fairly basic 4K projects (a handful of clips, some basic grading, occasional noise reduction on one or two brief clips, some audio edits, etc.) on an M1 Mac Mini with 16 GB of RAM. And it worked fine. It rendered pretty slow, but it worked. So I’m sure the 13 Pro would also do fine for that. But on the other hand, I no longer use an M1 Mini with 16GB of RAM, lol. Longer projects, more clips, and more effects all made me want more RAM and more GPU power.
