Deciding between the 13 and the 13 pro
Hello fellow Framework fans!
I recently purchased a Framework 12 that I’m enjoying quite a bit and am, maybe lucky or not, in a position to need to look at getting my second Framework purchase already!
As someone who is a relatively ‘light’ user - most of my work ends up on the web, some like QGIS work, things like that, I’m debating between the 13 or the 13 pro. I’m attracted to the look of the pro, but I also know that I may not really ever use the machine’s power for anything.
That being said, it sure is a nice looking machine!
I also do have some ddr5 that I could reuse, so not having to make the jump to the LPCAMM does have some appeal.
Anyone else live with this particular problem?
Grab AMD-based 13 Pro. You will get latest abd greatest chassis and still able to re-use your DDR5 ram sticks.
Interesting. I never found much about that as an option. Seems like all the reviews were intel.
You just need to go to the web site and open configurator.
Most reviews are for Intel board since it was released along with 13 Pro model, while AMD motherboard is from last year and was reviewed and tested already.
Thanks for the information!
If you don’t need the speed of LPCAMM2, go for the AMD. Your per-gigabyte price for RAM is about half with new DDR5, and of course it’s even cheaper still if you already have sticks to reuse. I don’t think LPCAMM2 is worth it at present, especially given the RAM downsizing that some people got their pre-orders.
Thanks. I’m not going to get into the LPCAMM2 stuff at this point. It may be years till that’s something that I’d be ok with from the market with. Question is the AMD pro or regular Framework. That black, grey, and orange keyed Pro keyboard is so nice looking!
If you only ever use it on a desk, probably doesn’t matter. If you will use it on a lap or haul it around a lot, the new chassis really is much stiffer and nicer.
Thanks. I would be in the bag a good bit between different sites, so that would matter for sure.
It’s worth noting that is only available wit the US keyboard layout. I’d have loved one here in the UK, but only with a UK layout.
That’s good for me since I’m in the USA.
I looked at everything and ended up going with the Pro Intel. It was actually a little cheaper getting the 16gb with it than the AMD and buying the memory I’d need.
Add in that I’ll just sell my extra 8gb stick of ddr5 and it works out. Now just to wait till December!
