Ubuntu 24.04
Which kernel are you using?
When using the built-in kernel, everything was working.
I’ve cloned the GitHub - eswincomputing/linux-stable on branch 6.6.18-EIC7X
kernel compiled successfully, it appear at GRUB at first run but it did not work properly. Turns out on the install, it was missing some dtb, when grabbing the dtb from the current kernel, the machine can’t pass the “RISC-V X AI” screen.
This is exactly what I wanna know. (also which bootloader this thing is using)
Additional info:
When plugging the USB-C cable to the UART extension, I can see a file FAIL.TXT with message
`The interface firmware FAILED to reset/halt the target MCU`
