Desktop Ryzen™ AI Max+ 395 Cases
Hello, Just call me Russ. i love buying a testing new pc cases with my build.
Frame Work AMD AI Max+ 395 128gb ram motherboard, two 4tb m.2’s, the AMD wifi adapter, and an Nvidia 3090. To use the 3090 i a have an pcie 4 x16 to pcie 4 x4 adapter. i mostly use the nvidia card for AI, and extra vram.
SGPC K66, works nicely, but lacks air flow,
Cooler Master NR200, wonderful case, plenty of air flow, and pretty small.
Latest case, i am using right now, Fractal Design Ridge, the reason i am using this case is because it fits my 3090 perfectly, and allows okay air from with out mods, with mods to put 2 60mm fans on the motherboard side of the pc, allows great exhaust and plenty of cooling.
What a lovely-looking case! I expect with all that internal space, you will get very good cooling.
See also this thread: For MB purchasers: what case are you getting?
the Fractal Design Ridge puts the fan right against the side panel, with no exhaust since i have a gpu in it, and the SGPC is just really small xD
