Devuan Excalibur on Framework 16
I didn’t see “Devuan” listed as a “Community Supported” Linux distro (and there’s no “devuan” tag yet), so I thought I’d add a topic for it.
(If a Devuan topic is covered elsewhere here, let me know and I’ll stop updating this one.)
On a Laptop 16 with the “Ryzen AI 300 Series” CPU, Devuan Excalibur (kernel 6.12) can be installed, and it even boots. :slightly_smiling_face:
I upgraded my BIOS from 3.04 to 3.05 before starting, but I don’t if that’s a factor.
I started with the Devuan image “devuan_excalibur_6.1.0_amd64_desktop.iso” and a clean M.2 drive (no previous OS).
When booting from that image, the installer will complain about CD-ROM and/or other hardware initialization issues and then pause; after around 20 seconds or so, it will continue by itself, no key presses needed.
After installation, kernel 6.19 can be installed by switching the apt sources.list file from “excalibur” (a.k.a. “stable” in Debian suite terms) to “freia” (“testing”). The Devuan devs recommend using codenames (such as “freia”), but the suite name “testing” works for me, so, after the initial installation completed, I changed my entire sources.list file to this one line…
deb http://deb.devuan.org/merged/ testing main non-free-firmware non-free contrib
…then did “update”, “upgrade”, etc.
My installation is still a work in progress, so I don’t know yet if everything will work as expected (such as audio); I’ll post updates.
I use Debian 14 Forky on a FW13 AMD and don’t think there’s a huge difference between Debian and Devuan for stuff you actually run – but the bedevilment is in the details.
Here’s one: Has Devuan moved over from /etc/apt/sources.list to /etc/apt/sources.list.d/debian.sources in this new yaml-like deb822 format?
Hi, Kenny,
It looks like Devuan defaults to the old-style sources.list format. Since it’s a Debian derivative, it might support the deb822 format, but I haven’t tried (because the old format still works for me).
–Dave
Good to know. I’m about to install on a Framework Laptop 13 Ryzen AI 5 340.
Interesting, good to know.
