dGPU Port not working with USB-C only display
Hi there,
I recently received a portable screen that accepts either one mini HDMI cable + one USB-C cable for power delivery or one USB-C cable for both video and power delivery. My question regards the second scenario, where I connect just one USB-C cable for both.
When using the side ports, this works perfectly fine: The screen powers up, gets recognized and is used by my OS (Linux).
But this doesn’t work with the dGPU Port in the back: The screen powers up, doesn’t get recognized and goes back to sleep.
Is this what should happen?
That rear port is just USB 2.0 + DP Alt Mode. On gen2 GPUs there’s also PD charging of the laptop available, but I suspect that no more than the 75W the PCIe slots can handle.
I checked and it charges my li-ion 1.5V AA batteries, so it’s probably delivering protocol-mandated 5V/500mA, but not more.
Your screen probably needs power delivery and is lighting up for protocol negotiation.
Are you using Windows or Linux? If linux, depending on the DE/WM you might need to wake up the dGPU to get recognised by the compositor. I use a natuilus bug that enumerates all GPUs waking up the dGPU.
Maybe windows has similar behaviour that if dGPU is in a sleep state it won’t check for new monitors connections before the dGPU wakes up.
Oh, sorry, I forgot to mention that the screen powers on and then displays “No signal”.
Switching the signal doesn’t do anything.
I’m using Linux (Endeavour OS) with KDE Plasma. I have no clue how to tell KWin to please use the dGPU for that screen…
What’s the name/brand of that external display?
I have this display: Amazon.com: CAPERAVE Portable Monitor Gaming 2.5K 120Hz, 16" 2560x1600 QHD 16:10 400 Nits HDR FreeSync Portable Monitor w/Speaker Sleeve Case, External Screen for PC Laptop Game Console : Electronics
It works fine in the dGPU port without external power.
It’s a screen from a kickstarter, the LiftVue S16Q: https://www.kickstarter.com/projects/832262630/liftvue-156-inch-portable-monitor-with-lift-stand/description
After you connect the display check
cat /sys/class/drm/card1/device/power_state if its not D0 then you need to open an application, like a game, to wake up the device.
Thank you for that hint, already forgot that I can check it that way.
What I found out:
  • I need to do some magic thing, to have the dGPU even power up the screen (tried it in D3Cold and D0 multiple times, switched some screen settings around and at some point it powered on in both D3Cold and D0…)
  • The screen powers up, shows the „no signal found“ message and turns off, regardless of dGPU state
You can check with amdgpu_top if the dGPU even sees the connector occupied.
How would I do that?
I skimmed through the amdgpu_top TUI and saw nothing that screamed “I’M THE CONNECTOR” at me :sweat_smile:
this is in GUI but I assume TUI has similar dropdowns.
