DGX Spark vs. Strix Halo - Initial Impressions
Heh, turned out VLLM compiles and runs just fine without NVidia-provided container. Just needed to set an environment variable specifying the arch.
In other news, there is some new activity in amd-dev branch of vllm project, so hopefully some improvements are coming in 0.11.1 release. But amdsmi python package is still crashing, so there is that.
what strang is that the one from fedora 42 work.
$ amd-smi version
AMDSMI Tool: 24.7.1+unknown | AMDSMI Library version: 24.7.1.0 | ROCm version: N/A
no, not this one. amdsmi Python module, and only on cleanup. amd-smi commandline tool works.
look there is someting wrong with amd-smi for rocm-7+:
  • fedora 42 / rocm 6.3:
$ amd-smi list
GPU: 0
    BDF: 0000:c1:00.0
    UUID: 00ff1586-0000-1000-8000-000000000000
    KFD_ID: 29672
    NODE_ID: 1
    PARTITION_ID: 0
  • fedora 43 / rocm 6.4:
$ amd-smi list
WARNING: User is missing the following required groups: render, video. Please add user to these groups.
GPU: 0
    BDF: 0000:c1:00.0
    KFD_ID: 29672
    NODE_ID: 1
    PARTITION_ID: 0
  • fedora 44 / rocm 7.0:
$ amd-smi list
GPU: 0
    BDF: N/A
    UUID: N/A
    KFD_ID: 29672
    NODE_ID: 1
    PARTITION_ID: 0
Note: all done on toolbox runing on silverbue 42 …
Strix Halo on Framework MB:
  • FA: on
  • mmap: off
  • GGML_CUDA_ENABLE_UNIFIED_MEMORY=ON
  • ngl: 999
  • n_ubatch=4096
  • backend: rocm
model size params test t/s
Mistral-Small-2506 43.91 GiB 23.57 B pp1 4.69 ± 0.00
Mistral-Small-2506 43.91 GiB 23.57 B pp2 9.19 ± 0.00
Mistral-Small-2506 43.91 GiB 23.57 B pp3 11.23 ± 0.00
Mistral-Small-2506 43.91 GiB 23.57 B pp4 12.86 ± 0.01
Mistral-Small-2506 43.91 GiB 23.57 B pp8 25.37 ± 0.04
Mistral-Small-2506 43.91 GiB 23.57 B pp12 37.53 ± 0.06
Mistral-Small-2506 43.91 GiB 23.57 B pp16 49.17 ± 0.08
Mistral-Small-2506 43.91 GiB 23.57 B pp24 70.87 ± 0.15
Mistral-Small-2506 43.91 GiB 23.57 B pp32 89.94 ± 0.45
Mistral-Small-2506 43.91 GiB 23.57 B pp48 122.01 ± 0.61
Mistral-Small-2506 43.91 GiB 23.57 B pp64 145.84 ± 0.60
Mistral-Small-2506 43.91 GiB 23.57 B pp96 207.52 ± 0.55
Mistral-Small-2506 43.91 GiB 23.57 B pp128 269.40 ± 0.95
Mistral-Small-2506 43.91 GiB 23.57 B pp192 229.28 ± 0.15
Mistral-Small-2506 43.91 GiB 23.57 B pp256 291.95 ± 0.70
Mistral-Small-2506 43.91 GiB 23.57 B pp384 358.48 ± 0.89
Mistral-Small-2506 43.91 GiB 23.57 B pp512 418.56 ± 0.65
Mistral-Small-2506 43.91 GiB 23.57 B pp768 401.40 ± 1.40
Mistral-Small-2506 43.91 GiB 23.57 B pp1024 438.28 ± 1.35
Mistral-Small-2506 43.91 GiB 23.57 B pp1536 439.35 ± 0.80
Mistral-Small-2506 43.91 GiB 23.57 B pp2048 438.40 ± 1.04
Mistral-Small-2506 43.91 GiB 23.57 B pp3072 432.32 ± 0.48
Mistral-Small-2506 43.91 GiB 23.57 B pp4096 423.00 ± 0.47
Mistral-Small-2506 43.91 GiB 23.57 B tg16 4.69 ± 0.00
Mistral-Small-2506 43.91 GiB 23.57 B pp512+tg64 38.69 ± 0.01
The user in toolbox is not a member of the required groups.
:~$ ll /dev/kfd
crw-rw-rw-. 1 root render 235, 0 25 oct.  11:21 /dev/kfd
:~$ ll /dev/dri/renderD128
crw-rw-rw-. 1 root render 226, 128 25 oct.  11:21 /dev/dri/renderD128
it is not needed with fedora, there is rw for all user. So the chech is “wrong”. I never need it on this OS. (may be needed on server / coreOS release?)
and rocm work fine without.
⬢ [zzzzzz@toolbx ~]$ getfacl /dev/dri/card1
getfacl : suppression du premier « / » des noms de chemins absolus
# file: dev/dri/card1
# owner: nobody
# group: nobody
user::rw-
user:4294967295:rw-
group::rw-
mask::rw-
other::---
and have user ACL right too. on cardN.
I try to add groups:
sudo usermod -a -G video,render $LOGNAME
But it did not work , did not add user to the groups.
Edit: find how to add user in this groups on host but not how to have them in toolbox. I have to look what is th “good” way for that (and after if is is realy needed…)
