Did my 13 pro just fry itself?
I got my 13 pro two weeks ago
hx370 64g memory
Yesterday I got USB issues where two ports stopped supplying any power (even without expansion cards inside)
Then today it stopped charging
And finally when I tried plugging it off and back on the screen went dark.
It will not turn on anymore. I removed the input cover , swapped chargers, tried the MB button, unplugged the battery, but nothing works.
One thing I noticed is that if I connect the charger the power button on the input cover (fingerprint sensor) gets very hot very quickly.
The charger is a brand new 100W gan charger (ugreen brand) with an associated cable .
Should I return it while I can or go through support ? Is this common ?
Sorry for the bad punctuation, I’m typing on my phone now…
We are all end users on the forums here. Contact support and get a ticket started with them. Try a different charger or no charger at all (if the battery is not totally drained)
It is not totally drained , it had ~25% , but it will not start at all no matter what
I’ll ask support but keep monitoring here as well
If you plug in the official charger, do you get the adjacent LED light up? This sits between each pair of expansion cards; you have two, and you can expect the one adjacent to the charging cable to come on.
(The lamp will be orange when it is charging, and white once it is fully charged).
Hi,
Sounds like a hardware problem to me. Contact official FW support via their web site form.
I do not have the official charger, but a LG USB C display (90W PD according to framework_tool) and the ugreen one (100W PD).
With both, the corresponding LED used to light up while plugged in , but this is no longer the case.
OK, yes, contact support. Return it if you are risk averse, so as to beat the month return window, but then you’d still need to buy a laptop from somewhere else. Personally I’d just go through the support process; they will probably send you a new mainboard.
Thank you for this advice. My fear is that there could be a subtle interaction between my setup and the board’s power design , which could damage the replacement main board as well if my setup hasn’t changed.
But I have no idea how to rule this out.
If you aren’t using a docking station, then just go through the support process, get it fixed, and then stick with the power brick that comes with the laptop.
I have a uGreen PD battery and it is excellent, but it is not impossible that your PD charger caused a problem. Equally, you could just have had a bad FW unit.
Consider purchasing a Framework power adapter with the Pro machine even if it is just for the peace of mind that using their power supply made by them has a better chance at being a quality source of power vs. some of the 3rd party adapters out there. UGreen has been around for a while and most people have had success with them, though I do not know if I personally would rank it higher than someone like Anker, Delta, or some of the laptop branded ones just from a QC standpoint.
With what is on hand right now; I would trust the LG one built into the monitor over the UGreen. Keep in mind that if the board is toast from a power issue that is not covered under warranty necessarily unless it was a Framework power supply that caused it.
It is a little odd that one side does not still work but it can happen both ways though.
Is it really warranty-voiding to use a non-framework charger ? I can never guarantee I’ll only use framework chargers, because trains, docking stations, cars, power banks, etc
I don’t think any of us know that categorically (i.e. what is in FW customer service manuals) but it makes some kind of sense. I should think if I connected a USB wire up to mains voltage and plugged it into my Pro, I could not reasonably expect the laptop to be fine afterwards. Of course, where the device looks like it should be USB-C compliant, I hope that FW would be lenient.
I myself use a Dell docking station, and it has been fine, for power and video and peripheral connections. Perhaps a good compromise is to stick to recognised brands?
Not necessarily warranty voiding to use a non-Framework power source. If a board is damaged from a bad power source though it may be considered user damage which would not be a defect in the device.
USBC PD is fairly well standardized however there are companies who put out lower quality products that do not have the same design protections and adherence to standards (usually as a cost savings reason). Just something to be aware of.
Personally I would return for a full refund if you’re still inside the window and support can’t give you a quick resolution. Tons of people have had issues with USB ports giving out on these machines (just search), and I can certainly say that I never once have plugged any non-Framework charger into my machine, and the ports still go out sometimes.
You can try support obviously, and see what they say. But a lot of times what they’ll want to do is send you a “refurbished” part which someone else had sent back because they were having issues with it… if you’re happy with that solution then sure, but returning for a refund is also a method that’ll be guaranteed to make you whole.
When you say “the ports still go out sometimes”, is this a recoverable state or is it damage as well ?
It’s recoverable with a reboot. Still not ideal; I’ve had it happen during a backup to an external USB drive for example.
Take some of that with a grain of salt. If there was as widespread of an issue with USB port failures it would be all over these forums in particular.
Refurbished is not the same as reconditioned. Framework may send a replacement part that has been used previously but it should perform to the same level as the original part that became defective.
At least with a part that has gone through Framework someone verified it’s functionality before it left so it does not become another warranty issue.
Returning the machine is an option. Though it may be an expensive one if bought before the LPCAMM2 memory prices went even higher. Then there is the joy of waiting months to repurchase the same machine.
Everything being made today is going to have a small percentage of product that develops an issue. This is why warranties exist so there is some form of assurance that a device is going to last.
I preordered at a much better price than current, so returning and repurchasing would cost an additional 500€. I chose the risky path and went for the repair. I loved the machine so much while it worked, I’m keeping it and :crossed_fingers: the next MB will hold up for longer.
IDK man, I can only report my experience. I had issues with my laptop, support sent me on this incredible wild goose chase of random debugging steps, at the end of which they sent me a “refurbished” mainboard which hadn’t even had its BIOS reset to factory defaults, and which also developed problems shortly after. Earlier today, one of the USB ports randomly failed and I couldn’t use my mouse for a while.
I recognize that that’s not everyone’s experience but that’s what happened to me, and I’ve heard from a few different people who went through multiple rounds of sending back one mainboard only to get a new one that also had problems until they finally just gave up and lived with the problems.
I’m not saying that’s everyone’s experience, and the laptop is honestly very very nice. It’s wonderful kit on the whole and I like the mission of the company overall. And, it seems like support is maybe getting more responsive recently (just seeing in the forums, I’ve seen them being more willing to help people out with defective-hardware issues than they were in the past so that’s definitely a good thing). I’m just reporting how it worked out for me when I say these things.
Makes perfect sense. Hope it works out + best of luck :crossed_fingers:
