Difference between X7 358H and X9 388H (performance and battery-life)
Since the Framework Laptop 13 Pro was announced with the different hardware configuration options, I have been waiting for reviews/reports to appear to come out that compare them. However, I haven’t seen too much out there, especially direct, one-to-one comparisons.
While I’m also curious about the impact of RAM capacity and NVMe SSD choice on performance and battery life, what interests me most is the difference between the X7 358H and X9 388H.
On paper, both CPUs look extremely similar with the same core configuration and integrated GPU, but somewhat higher CPU clocks on the X9.
So the question is, how do they differ day to day?
Do the higher clock speeds make a noticeable difference in CPU performance?
Especially with the same power limits. And in which use cases?
Does the X9 use more battery because of its higher possible clock speeds?
Or is battery life basically the same because it doesn’t need to run at higher clocks for most tasks?
Or could it even use less energy for certain workloads because it finishes tasks faster?
How much do RAM capacity and NVMe SSD speed affect the performance difference? Does it only make sense to get the X9 if the other components are top-tier as well?
I get that most people will buy only one machine, rather than multiple different configurations, but I’d hoped that cross-referencing reviews, benchmarks, and owner reports would help.
I’d also love to see more reports, write-ups, or videos from Framework themselves comparing the configurations in their own usage and testing. Not necessarily as formal reviews, but as information about the performance they observed internally and which configurations they recommend for which workloads. I’ve seen their general processor-selection FAQ, but it would be interesting to see some actual measurements behind those recommendations.
I would be thankful for some guidance as the shipping date comes up for my pre-order :slight_smile:
