Warning, this post might just seem like a rant, so I want to preface it with the fact that my frustration comes from me loving this laptop when it was fully working and I really support Framework’s mission.
It seems like the USB-C ports on my 7940HS mainboard are prone to failure (or I’m just really unlucky). After communicating with Framework’s support for a few months a bit ago, we concluded my unit has a faulty hardware controller somewhere that shops don’t seem to want to fix, so my Port 6 is fully nonfunctional. This past week my Port 1 started to fail and not register at all until I downgraded to the 3.06 bios, where the USB-C port only works rotated one way, meaning the only module I can use on it is USB-C since every other port isn’t recognized as it is “upside down” from the working orientation, but I guess the USB-C module is just a passthrough.
What I’m most disappointed in is my lack of options to repair. The shops around me said they won’t be able to fix the USB controller issue and my local shop said their source for USB ports doesn’t have the kind used on the FW16.
I wish there was a way I could get this repaired normally since it’s out of warranty, but I’ve been told by Framework my only option is to buy a new mainboard, which just feels silly to do with my 7940HS as the processor is performing rock solid on what I need and the AI 300 series just doesn’t seem to justify the price for the upgrade.
Sorry if it seems like a rant, but I’m just frustrated with the situation and wish that the laptop also had a place to repair the electronics beyond just replacing individual parts. I hope there will be a good way to run this laptop headless for when the next generation of FW16 comes out, but I’m not sure how that’ll be with how the cooling works.
Why not ask the repair shop for the exact part numbers and source them yourself?
The other thing lacking from FW is a tool to flash the PD firmware alone, so you can replace the chip and then flash it easily.
I believe the larger issue here is that the ports are mid-mounted, so they sit in etchings in the mainboard and therefore lower than a standard top-mounted port.
These are common in smartphones, so a smarthpone shop should be able to deal with them - provided they replace individual ports.
How are you breaking the ports in a manner that needs physical repair? The only things connected to them should be the expansion modules and those are in a fixed location that can’t break the port.
Lots of people have been experiencing USB port failures. Hard to say exactly what percentage of users it is, but it seems much more likely to be a design flaw or some commonly-faulty component as opposed to something this particular user is doing.
For what it’s worth, I have intermittent port failures, but they don’t happen if I am super-careful with the grounding situation of my machine (grounding the charger, only plugging powered accessories into it if they are also grounded, grounding myself and not touching the machine if I’ve been walking around or something). That’s part of why I lean toward it being a design flaw.
The couple of recent reports from users saying something about connections to ports only working with connections made with a certain orientation sound to me like they’re most probably related to physical damages (probably cables or connectors).
This doesn’t speak to the other types of port failure reports that can sometimes be fixed via EC reset.
Here are 30 different instances of USB ports failing for users:
Hardware replaced (mainboard, card, or board)
Piece of mainboard partially melted (FW13 11th gen): top-left charging port died; melted component found; Framework replaced case and mainboard. Later pages have more reports, including one org with 1 of 24 laptops affected.
Post code 6 8 9 10: same user’s follow-up. Replacement board had top-right port charging issues after warranty, then stopped powering on.
Motherboard failed mysteriously (12th gen): USB ports failed on and off until no boot; support couldn’t find the cause; repair shop said board too damaged.
It is 30 because I asked Claude for 20-30 instances, not because that was all it could find. In particular I think the commonality of “I had one machine break and then the replacement also had the same issue” indicates that it’s not some kind of crazy outlier when this happens.
I have had two mainboards, and one of them has had this USB failure issue. My personally measured failure rate is 50%, and I’ve never once used any non-FW charger with this machine. Like I said, I actually did a decent amount of investigation to sort out what was going on and I’m reasonably confident now that it is a design flaw related to grounding of the mainboard (and it works reliably as long as I operate under that assumption).
I get it. Framework’s one of the good guys, and so it’s natural to want to shield them from criticism if something does go wrong, and assert that it’s probably the user’s fault. I don’t think that is fair to people who are experiencing these failures though.
The issue is that I haven’t done anything out of ordinary that would break the ports. This is an issue with the ports on the mainboard themselves, and I only plug modules in to them like intended. I assumed the rails would lead to less play/variation while plugging them in, so I don’t know what else it could be. Love the machine and the idea of it, but man it kinda just sucks.
I actually found the part numbers (they were out of stock), but by the time I got back to them about it, I started to worry that they misdiagnose one of the ports for replacement instead of the controller chip. Maybe some miscommunication on someone’s end, but they did leave the door open for me to come back in if they’re able to source it later. Might just go to a different shop once I’m not relying on it for projects though.
Unfortunately port 6 was not fixed by doing the EC reset following support’s instructions (apparently some kind of controller chip failure). There shouldn’t really be physical damages with how the modules are slid in via a rail though, so I’d assume there wouldn’t be much room to damage it compared to directly plugging into the mainboard port. I’d be okay with one of my modules failing, but we’re talking about the mainboard port here.
my framework 16 (number 21 in the list) was never fixed. I had a lot of quality issues with my framework 16 and that was the last straw. I’m done with framework I bought a Lenovo t1g to replace it and 6 months later I am still very happy with the Lenovo.
Yep yep, yours did not sound akin to other failure reports that may be fixed via EC reset or other such processes - I was filing yours with “connections to ports only working with connections made with a certain orientation sound” in my post.
One possible idea:
It’s probable that you’ve done this before/while speaking with support about the issue, but if you HAVEN’T yet, it might be worth your time to get a new USB-C cable to see if the cable you’re currently using has some physical damage that’s creating the “only works when oriented one way” problem. Considering USB-C ports are by design bi-directional, if you’re only able to charge your FW16 when the cable plug is facing one direction, I’d be suspecting the cable first - it’s the most likely part to sustain some minor physical damage because of how much varied physical manipulation it takes during regular use.
Also of note, if you’re purchasing a new cable, you’ll want to make sure it’s rated to handle the wattage your power supply can put out (180W or 240W if you have one of the chargers Framework supplies for our FW16s).
Are you HONESTLY suggesting that he went through full Framework debugging steps which ended with them recommending a new mainboard, and then also took the thing to a repair shop, and every single person involved was just testing with the same singular faulty cable?
Definitely - I’m not of the mind that it’s a crazy outlier when port-related failures occur with Framework products!
I briefly scanned through the 30 posts you linked. All of the links [well, most of them - “2.” is a dead link] you pasted into your message do have discussion about various hardware/software issues that mostly tie into port-related failures. Keep in mind, my message that you’re replying to was specifically about a few recent posts (like Jarhead’s) that discussed port failure modes that included discussion of USB-C cable orientation. A few things I found notable when clicking through the links:
2. This is a dead link. I get "page not found" when clicking it and couldn't find what post that should have linked to when running a few searches for similar post titles.
6. This was a problem in which a user's charger sustained physical damage. Framework was super chill and replaced the user's mainboard, charger, and expansion cards (physical damage generally voids warranty but I'm not making any claims on how the user's charger got damaged).
7. It sounded like some sort of electrical event fried this user's mainboard. Their unit was out of warranty but Framework still sent them a new mainboard and bottom plate - pretty chill of Framework.
10. The user said that their daughter spilled water or some other liquid on the machine and that fried their board.
13. The user bought a used FW13 and one of the USB-C expansion cards failed (nothing to do with the mainboard and there's no indication of a design flaw - just that an expansion card died after an unknown number of operating years).
15. This one doesn't mention anything about hardware being replaced or this particular user's problem getting sorted out.
16. This is a pretty complicated post. There are reports from the user of shipping damages, some different physical damages, one or two mainboard replacements, usage of third-party equipment that may or may not be working properly and rated for the particular wattage their FW power supply required. It's fair that it was filed under "hardware replaced," but that doesn't really add to this discussion thread.
18. May or may not have been fixed with an EC reset. The user didn't respond after someone suggested that.
23. The user's problem was rectified by resetting their mainboard.
27. The specific post in the thread you linked to was of a user reporting that they damaged their laptop using a third-party magnetic USB-C connector to charge their laptop. They end it with warning others not to do what they did.
Fair! I’m not saying things like “all these problems are outliers” or “there are no undiscovered design flaws” or “you used a non-FW charger and thus you’re the source of damaging your machines.” I tried to slightly redirect the conversation back to the initial poster of this thread’s problem when responding to you - I tried to be pretty specific in my post. All I said was this:
"The couple of recent reports from users saying something about connections to ports only working with connections made with a certain orientation sound to me like they’re most probably related to physical damages (probably cables or connectors).
This doesn’t speak to the other types of port failure reports that can sometimes be fixed via EC reset."
You may be speaking to more people than just me with that comment, but for me, I think what you’re saying here is pretty agreeable. It can be a common theme in this forum to say Framework is the good guy; it can be pretty common to see someone diminish the possibility (or reality) of design flaws by asserting that the user broke something with no evidence to back them up. I do like Framework (my laptop has served me EXTREMELY well), I appreciate the mission, and I like to tell people of my good experiences with what I’ve bought from them. At the same time, Framework’s a company: they need to be profitable to survive (which can have negative effects on users by prioritizing the need to develop/sell new product over the need to perform crucial sustaining engineering - including but not limited to BIOS updates). They’re also made of people. People can miss design flaws, take too long to respond to support tickets, and mess up in a million other ways.
I generally just want to help people out when they’re experiencing problems. I don’t work for Framework or anything - I’m just in the forums to keep up with new Framework developments, 3rd party developer projects, and to assist with troubleshooting when I can. I’ve been successful in helping a few people sort through some things and in pointing people to certain resources they couldn’t find. I’ve also presented some troubleshooting steps to people that got them absolutely NOWHERE (…possibly more often than successfully helping someone troubleshoot, although in my defense, sometimes it’s just important to check some things off on the hopeful path of finding a fix).
No - I’m asking if that’s the case because that detail is not listed in Jarhead’s posts here. The amount of times I’ve worked with someone to troubleshoot something and some of the simpler steps got glossed over is fairly high. I also started that section of my reply with this:
“It’s probable that you’ve done this before/while speaking with support about the issue, but if you HAVEN’T yet”
I’m just saying don’t blame the victim. That’s all. If you’re not doing that, then fine.
Part of it is 100% just me getting pretty irritated initially by @jared_kidd asking “How are you breaking the ports in a manner that needs physical repair?” which is a super unhelpful thing to say to someone whose Framework is breaking itself in this well-documented way that they do. You did leave a heart on that comment. But sure, if you’re now just trying to give helpful advice to OP, then I won’t stop you from doing that.
My issue with OP is he is saying the ports are physically failing, and then in the next sentence pivots to talking about them working again (ie. NOT failing) with a firmware downgrade. Your list of 30 links are just a mish-mash of many unrelated usb issues which does the opposite of helping the OP clarify his issue. A port physically failing is much different than the firmware disabling it.
I do agree that the 16 usb issues are terribly annoying and the fact Framework clearly doesn’t care to fix them (over 2 years now since the 16 was released with these issues) makes me and many others never want to buy a Framework again. Support is truly horrendous. And when you see more firmware bugs pop up when the firmware went from the 3.x series to the 4.x series it’s pretty clear the firmware developers have no idea what they are doing. Yes, I am frustrated as well.
The oddest thing happened the other day at work: several people reported ports shutting down when plugging in to docking stations or plugging in accessories in a certain order - crazy, inexplicable stuff. Sounds, familiar, eh?
Those were all MacBooks.
One of the most valuable hardware companies in the world can’t figure out power delivery via USB-C despite using chips designed in-house.
It’s no consolation, but perhaps we’re living in times of unreliable hardware?
I mean hardware faults can manifest intermittently sometimes, or be sensitive to software configs or other changes. I think there is a strong consensus that the USB ports on the FW16 mainboards are dodgy sometimes.
In any case it’s all good. I’m not irritated because the hardware has faults sometimes; even outside of bleeding-edge hobbyist type kit, it does happen. I’m irritated when Framework has a non helpful response to a user who they have clearly just shipped stuff to that is busted, or when it sounds like people in the comments here are doing apologia for it or asserting that the user must have done something to deserve what happened.
