This is a relatively new occurrence, which only popped up in the last two weeks or so. Every couple seconds, my computer will dip in performance, causing frame drops and such. I found that if I remove my DP card, this no longer happens, and it ONLY happens when my DP card is plugged in. Is there a way to fix this, or do I have to consider the DP card a loss and buy a different one?
There are possibilities, depending on what batch you are in, which port you are using the module in, if the EMI shields are properly installed (not pressed down tight) etc.
