Do I need new battery?
I could’t install windows 11 so I left it charged, months later I was ready to install windows but the battery had no power. I plugged the laptop & the light never turn on, without power nothing gets done.
Try removing the battery and see if it boots up.
Did you leave it plugged in, or with psu disconnected?
Did you leave it on suspend or powered off.
Was a charge limit set, or did you leave it at 100%.
The battery is likely fully discharged, plug the computer in and wait for hours for the battery to charge, or you can perform a BIOS reset
