DockFrame - Modular USB-C Hub with Framework-Compatible Expansion Cards
Im sorry if this has been asked before but im a bit confused about a few things.
First the PD port. Going off of the Crowd Supply page do i understand correctly that i cant leave a USB C expansion card in there to either use the port for power or data? I have to remove the expansion card to use it as PD slot? Based on this part: “a charger and a card cannot occupy it at the same time”
Second the Supercharge port. From what i understand it has a USB 2 Low-Speed connection to the DockFrame? Im personally not interested in any of the current tool cards so the question is would i be able to just put a USB A or C expansion card in that slot to use it with a low bandwidth device like a mouse or is that slot useless without the tool cards?
Last but not least the Dual USB C card. Does it support any form of PD?
The developers here seem to have Claude write their posts, with insufficient input and review, resulting in text that is confusing at best, and that alternates between making sense and seeming clearly wrong or nonsensical. Half the content makes the project more confusing rather than less.
The clearly wrong PD input or card statement appears to be written by an LLM that doesn’t have the context to know that there are expansion cards other than the newly-designed ones, and doesn’t understand that the point of the design would be to use a standard FW USB C card there. The design doesn’t make sense otherwise.
Similarly, the entire point of the isolated supercharge I/O ports, which do not appear to be connected to charging and do not appear to be actually isolated, is extremely confusing, as most of the information appears to largely be Claude babbling about details and caveats of unclear validity, without any simple explanation of the basic idea behind why the ports are there. My guess is that the ports appear to be intended to offer separate, additional power for a single card, primarily for the power supply card, though why EPR would be important or useful for a max 60W card is unclear. It appears that the data connection of the ‘output’ port is to the laptop port, while the power is to the input port; I assume this input port is the reason for the unhelpfully cryptic “not all seven carry USB data” statement. I also assume that the power isolation would mean that the power-isolated output port would not be usable without power being provided by the separate input port. I’m a bit baffled at the addition, and significant increase in size of the device, for what seems to be a single niche use case, but it may be that I simply don’t understand its purpose.
There are many components here that seem like things I want, which makes the confusing, extensive Claude-written content aggravating. The project would heavily benefit from a concise, human-written or at least sufficiently human-reviewed short summary explaining the overall design and intention.
I will provide a quick response of some of your questions later today.
The photos of the hub in the crowdfunding campaign is from a previous batch were we tried to have the supercharger port also connected o the rest of the hub. We just got the new batch with that port totally isolated as you can see in the photo. I will provide more details soon.
Your feedback is very useful, thanks for that.
Are you talking about cards like https://frame.work/products/usb-c-expansion-card?v=FRACCQ0002? If so, yes, you could use a usb-c extension card in the PD port if you want, as those card passes through power.
The supercharge port is designed for “power hungry” cards like the power supply, and other future cards that we have in our roadmap. Also it will be used for future addons on top of the dockframe (attached using the bricks studs enclosure).
Keep in mind that port is isolated from the rest of the hub, so if you connect a mouse in the supercharge port “A”, you need to also connect the supercharge port “B” to the host computer.
That means you will have two cables going from the dockframe to your host computer. One from the supercharge port and another for the hub upstream port (the one connected with the rest of the 4 downstream ports)
No, it doesn’t
Thanks for your feedback, we will take it into consideration for the next campaign updates, so is easier to understand.
You could connect existing Framework cards in any of the ports, including the supercharge port (see my reply above to another comment.)
The photo used in the campaign is from our previous batch where we been experimenting with that supercharge port. The new batch now has the supercharge port isolated (see the photo that I posted earlier today)
Yes, that port is mean to be used with separate power supply, and the main goal is for the power supply card and other future cards that need a bit more power. Also we plan to release some addons to attach to the top of the enclosure (a led matrix for example).
We could provide more details about this in future campaign updates (weekly emails that campaign subscribers get)
Point taken, I will improve that
Their hardware pictures were also Ai generated with USB C ports in impossible directions. I don’t understand why they are using Ai to write all their blog posts and generate the product pictures so I just personally wrote them off as a scam and moved on.
I’m probably wrong though.
We already sent prototypes to Framework team and they where presented in different events:
We used canva to improve quality of images, and colors and we use claude for the blog and other content because we are a team of two with full time jobs with very limited time.
I can take people complaining on how AI makes the content confusing and yes we can improve that for sure, point taken but something very different is accept being called a scam, that’s unfair
I get that it’s offensive, but it is my honest feeling when seeing AI generated blogs and images that are obviously incorrect. It portrays a lack of care behind the project. I’m also the type of person that would rather see a blog post that gets right down to the point instead of being overly wordy (AI’s tend to do the later). Thanks for the further information and I am glad I was wrong.
My suggestion would be to put up a human written blog post clearly listing all the features of this device (i’m still confused about which ports can do what), preferably in a bullet point list, no overly wordy and confusing explanations, just specs.
And even more importantly for a pre-release crowd-sourced project; put up a non-ai video with you or someone on the team actually demonstrating the product and explaining how it works. The AI videos also do a great dis-service to trust in the project.
Anyway, good luck. It’s awesome to finally see this coming around.
If I use the framework HDMI or DP card in the dock I won’t be limited to 4k60Hz like the limitation on the USB-C DP connection on the dock? This dock is perfect EXCEPT I use a single external monitor and can’t go back to 60Hz.
No, a card can’t output more than the dock’s DP port gives it, so the limit for now is 4K 60 Hz
One solution is to connect the display directly to your laptop and use dockframe for the rest of your ports
Gotcha, I will prepare something over the weekend.
Thanks!
I prepared that image with the latest pcb explaining the different ports. I will later in the week share the whole campaign update where I explain each port and also some other details about the enclosure.
