Does the sleep setting in windows power plan actual map to anything?
Or is this meant for laptops that have more custom buttons related to power?
It’s meant for only keyboards that have a sleep shortcut.
In windows though, even if you have a sleep button, it’s not going to do anything. You may as well go to the ‘settings that are unavailable’ and map all sleep to hibernate instead, it will be more effective
I thought tapping the power button might act as the sleep button and holding is power off. I don’t like how long it takes to power off when holding the power button that I made an autohotkey script to make alt + P power off.
I’ve had some issues with the laptop that may be a result of hibernating because they start as soon as I turn it on and are gone when I power cycle it.
