Dual Keyboard Firmware: Best of both worlds! (OpenRGB and VIA key mapping)
This was a long time wish of mine, finally fulfilled.
I really love that I can change the keyboard RGB in keyboard.frame.work, but it lacks customizability, for example I cannot set specific patterns or change the RGB to sync with music or other stuff. Also, it doesn’t really let me set a timer to turn off unless I go mess with the USB sleep / wake in NixOS. This comes with its own problems (for example, I have to wake the keyboard by pressing a random key before typing).
This firmware allows all of that into one package. It will let you configure your keymaps in keyboard.frame.work, the firmware will launch in VIA mode. Then when you close the page, you can open OpenRGB and it’ll stay in OpenRGB mode (taking your keymaps with you!). The dual-firmware will also shut the RGB off after 1 minute of no typing. This is done on the hardware layer, no configuration needed, and no messing with Linux configs. This ultimately saves battery, and its better when watching a movie!
Note: keyboard.frame.work WILL show errors that lighting commands are unavailable, this is normal. This is becasue these functions are now intentionally not implemented and go through OpenRGB!
