On windows 11 but it doesn’t matter since I had the same issue on Ubuntu. The issue is a little tricky. The letter “E” on my keyboard stutter and doesn’t work properly. I had this issue a few months back already and had bought a new keyboard (first gen). The issue was resolved for a few months but then the same letter started acting up again. I have no other issues except for this specific letter. My bios and keyboard firmware are up to date so this isn’t the problem either. A USB keyboard works properly as well. Does anybody have an idea on what’s happening and how I can resolve this issue? Any help would be appreciated. Thank you!
Sounds like it is just that key on the keyboard again. Contact support and see if they will warranty it since it has only been a few months.
By chance are any games played and the laptop keyboard is used? This can cause excessive stress on a few select keys sometimes that are frequently used or near frequently used keys.
Look for any flexing in that area of the keyboard when the E or surrounding keys are pressed. This can cause a trace on the circuit board to separate sometimes under physical and repeated stress.
