Ethernet Expansion Card Noisy LEDs
Is it possible to disable the LEDs on the Ethernet Expansion Card? (Linux)
If it’s not possible in SW, any tips? Since the case is transparent I can’t just cover them.
I haven’t found anything in the kb.
As the leds are part of the plug I found no good solution. The best was black tape :frowning:
If you can open up the card, black nail polish is very useful for dealing with overly bright leds XD
