NixOS
Which release version?
25.05 (BUILD_ID: 25.05.810767.3bcc93c5f7a4)
Which kernel are you using?
6.17.0 \#1-NixOS
3.05 (got scared of updating due to numerous issues seen with new BIOS update)
AMD Ryzen 7040 Series : AMD Ryzen 7 7840U w/ Radeon 780M Graphics
The issue only happens when the card is intensively used, I see it is getting a bit hot (I don’t have any way to measure precisely it’s temperature but I see it shutdown and reboot the lights, my router shows say that the network cable was disconnected)
I cannot reproduce the issue with the exact same Ethernet cable and my USB-C Thinkpad Gen 2 Ethernet Port (but the speed is capped at 1Gb/s instead of 2.5Gb/s)
I’ll be reaching out to support soon as I’m surprised this has not been reported by anyone yet, might be a faulty expansion card I got out of the box.
In my dmesg logs, I see :
[239280.611523] r8152 2-2:1.0 enp193s0f3u2: carrier on
[239288.036186] r8152 2-2:1.0 enp193s0f3u2: carrier off
[239291.875452] r8152 2-2:1.0 enp193s0f3u2: carrier on
[239770.083642] r8152 2-2:1.0 enp193s0f3u2: carrier off
[239773.923059] r8152 2-2:1.0 enp193s0f3u2: carrier on
[248759.266172] r8152 2-2:1.0 enp193s0f3u2: carrier off
[248763.106608] r8152 2-2:1.0 enp193s0f3u2: carrier on
[252453.345398] r8152 2-2:1.0 enp193s0f3u2: carrier off
[252457.185747] r8152 2-2:1.0 enp193s0f3u2: carrier on
[252469.473881] r8152 2-2:1.0 enp193s0f3u2: carrier off
[252473.313610] r8152 2-2:1.0 enp193s0f3u2: carrier on
To probably debug further, I’d need to enable maybe some kernel parameters to have a more verbose output from the driver r8152
