Expansion card issues with HDMI and USB driver missing
Dear community, since several months I am having the issue, that my HDMI-expansion cards frequently seems to lock up: I then have to remove and re-insert it. Windows will on re-inserting play the sound for “new USB-device detected” - however it does not play the “USB-device removed” sound when I eject the expansion card… Does anybody have the same issue and knows how to fix it?
My next but relatively new issue is that I am having driver issues. In Win10 device manager, there´s permanently a warning shown, that for 2 "USB (U… S… Bus)-Controller no driver can be found / no compatible drivers have been installed. I am not sure which consequences this has, at least today I found that my Gigabit Ethernet-to-USB-C adapter is only connecting with 100 Mbps anymore…
Would be great if anybody could help, thanks!
  • Which OS (Operating System)? → Win10 Pro N
  • Which release of your OS (Operating System / Windows 10, 11)? → Build 19045
  • Which Framework product → Laptop 13
  • and which generation → Intel 12th gen
